hurbie Posted October 27, 2023 Share Posted October 27, 2023 hello all , my LandRover 110 200tdi , is in need of a new battery , it has a winch , and on holidays a Engel fridge . is the better option a semi-traction (for the fridge) or a start battery for starting and using the winch .. at the moment i have a 100AH Bosch S5013. gerben Quote Link to comment Share on other sites More sharing options...
Wytze Posted October 27, 2023 Share Posted October 27, 2023 52 minutes ago, hurbie said: hello all , my LandRover 110 200tdi , is in need of a new battery , it has a winch , and on holidays a Engel fridge . is the better option a semi-traction (for the fridge) or a start battery for starting and using the winch .. at the moment i have a 100AH Bosch S5013. gerben Hey Gerben, In the 109 with the 35slt i use a yellowtop 75 amp. Never lets me down.. 900 amp of starting power. Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 27, 2023 Author Share Posted October 27, 2023 2 hours ago, Wytze said: Hey Gerben, In the 109 with the 35slt i use a yellowtop 75 amp. Never lets me down.. 900 amp of starting power. but 75 amps for the fridge seems a bit on the low side . Quote Link to comment Share on other sites More sharing options...
Wytze Posted October 27, 2023 Share Posted October 27, 2023 57 minutes ago, hurbie said: but 75 amps for the fridge seems a bit on the low side . How much does your fridge take? mine just 70 watt's. Or go for a dual set up? Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 27, 2023 Author Share Posted October 27, 2023 1 hour ago, Wytze said: How much does your fridge take? mine just 70 watt's. Or go for a dual set up? the Eurover will get a double setup with lithium , for now a single battery has to do . with the setup i have now i can run my fridge for 2 maybee 3 days and still be able to start without trouble's . (fridge is a Engel MR040) Quote Link to comment Share on other sites More sharing options...
Escape Posted November 6, 2023 Share Posted November 6, 2023 I'd go for the biggest start battery that fits (and is reasonably priced). You'll pay more for a semi-traction and it will be less suited to the short but intense load when winching. Just don't run the start battery too low too often. 😉 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 7, 2023 Share Posted November 7, 2023 On 10/27/2023 at 6:57 PM, hurbie said: but 75 amps for the fridge seems a bit on the low side . I've been told by a bettery supplier that a 50amp red top battery is equivalent to a 100amp lead acid so would assume the same for the 75amp yellow, so I guess it would be equivalent to around 150amp. I can vouch that a 50amp red top will start a Cummins 6bt from cold like it's an A series. Mike Quote Link to comment Share on other sites More sharing options...
