hurbie Posted December 14, 2023 Share Posted December 14, 2023 hello all , has anybody found a alternative for the connectors that fit the 200tdi fusebox (the connectors that hold the wire on one end , and the fuse on the other ) original numbers are STC4036 STC4035 STC4034 i tried autosparks, but they only sell a fusebox with terminals/connectors . (and to save the planet i only need the terminals/connectors) even Google can't help me find these 😞 (i can find them , but eye watering expensive ) Quote Link to comment Share on other sites More sharing options...
western Posted December 14, 2023 Share Posted December 14, 2023 Ask PaulMc on here or look at Vehicle Wiring Products or Car Builder Solutions. Quote Link to comment Share on other sites More sharing options...
hurbie Posted December 14, 2023 Author Share Posted December 14, 2023 45 minutes ago, western said: Ask PaulMc on here or look at Vehicle Wiring Products or Car Builder Solutions. @PaulMc this one ? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted December 15, 2023 Share Posted December 15, 2023 23 hours ago, hurbie said: @PaulMc this one ? Yes, that's me I've looked into alternative terminals, but haven't yet found anything suitable. The nearest I've found is another Lucas-Rists terminal, which isn't a perfect fit, and just as hard to find as the proper terminals. The generic 6.3mm (¼") 'Lucar' terminals, I've found to be too wide to fit into the fuse box's cavities. Quote Link to comment Share on other sites More sharing options...
hurbie Posted December 15, 2023 Author Share Posted December 15, 2023 57 minutes ago, PaulMc said: Yes, that's me thanks for your replay , i'll keep an eye out for these , if i can't find anything in time, i'll ditch the 200tdi fuse box and find something else .... 1 Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted December 25, 2023 Share Posted December 25, 2023 I found some Chinese ones on eBay some time ago. There are several sizes so you have to be careful and very specific. I’ll try to find what and where I ordered from. Success! On eBay I ordered from Boamain. They’re brass, female, non insulated, and onn the flat side there is a small tab that catches on the fuse holder block to prevent it being pushed out when a fuse is inserted. https://baomain.com/products/b01mpz2t2c Mike Quote Link to comment Share on other sites More sharing options...
hurbie Posted December 26, 2023 Author Share Posted December 26, 2023 12 hours ago, Troll Hunter said: I found some Chinese ones on eBay some time ago. There are several sizes so you have to be careful and very specific. I’ll try to find what and where I ordered from. Success! On eBay I ordered from Boamain. They’re brass, female, non insulated, and onn the flat side there is a small tab that catches on the fuse holder block to prevent it being pushed out when a fuse is inserted. https://baomain.com/products/b01mpz2t2c Mike these are "normal" 6.3mm connectors , they are not the right ones ,blade is too wide for the fuse , and it lacks a "pusher" plate on the inside to make a secure connection with the fuse .... "close , but no sigar ..." Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted December 26, 2023 Share Posted December 26, 2023 Sorry, you must have a different set-up. I’ve used nearly a hundred of these in my LR fuse box and relay mounts. They fitted just fine. Mike Quote Link to comment Share on other sites More sharing options...
hurbie Posted December 27, 2023 Author Share Posted December 27, 2023 21 hours ago, Troll Hunter said: Sorry, you must have a different set-up. I’ve used nearly a hundred of these in my LR fuse box and relay mounts. They fitted just fine. Mike these are perfect for the relay mounts . Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted December 27, 2023 Share Posted December 27, 2023 ^^ and for the fuse assemblies in my 1991 110 CSW. Mike Quote Link to comment Share on other sites More sharing options...
