trod Posted January 13 Share Posted January 13 Hi dose any one out there know how to remove this pull switch,with out drilling i do not think that it is a grub screw. Thanks Trod Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 13 Share Posted January 13 I'm pretty sure it is a small spring loaded pin, it should just push in and then you can draw it off Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
tuko Posted January 13 Share Posted January 13 2 hours ago, Stellaghost said: I'm pretty sure it is a small spring loaded pin, it should just push in and then you can draw it off Regards Stephen exactly that, sometimes they are rusted so a drop of WD40 will get it moving. Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 13 Share Posted January 13 WD40 might get it if you are lucky. Proper “penetrating oil” is more likely to work. Unfortunately, it might be stuck solid and require the destruction of the plastic knob, which I believe is long since unavailable. You may be able to break the pin free if you use some sort of jawed tool with a pin to push on the embedded pin and a load spreading form to protect the plastic. Don’t go at it with pliers. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 13 Share Posted January 13 What they said - it's a spring-loaded brass pin that you need to push in, you may be able to do it by inserting something in the hole and then gripping with pliers to give it a good push - carefully to avoid damaging the knob of course! Quote Link to comment Share on other sites More sharing options...
trod Posted January 13 Author Share Posted January 13 Yes a big thanks to everyone i was just to push it in! 1 Quote Link to comment Share on other sites More sharing options...
Iain Posted March 30 Share Posted March 30 On 1/13/2024 at 2:08 PM, Snagger said: Unfortunately, it might be stuck solid and require the destruction of the plastic knob, which I believe is long since unavailable. Good quality reproduction knobs are available. (insert your own joke here) https://embertonimperial.com/products/land-rover-series-2a-3-dash-repro-windscreen-washer-wiper-switch-knob-90575153?_pos=4&_sid=b562dcebe&_ss=r Quote Link to comment Share on other sites More sharing options...
