Range Rover Ash Posted February 1 Share Posted February 1 HI, I have a 1995 HSE range rover 4.6 petrol auto, it conked out the other day and won't start, i took off the fuel pipe going to rail, and it's dry, no fuel coming at all, is this definitely a fuel pump gone? Thank you for any replys! Quote Link to comment Share on other sites More sharing options...
Range Rover Ash Posted February 1 Author Share Posted February 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 2 Share Posted February 2 Is the pump running? Checked the fuse to the pump? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 2 Share Posted February 2 ECU controls the pump, it won't run the pump if it doesn't think it needs to, which is based on various criteria. Do you have spark? Quote Link to comment Share on other sites More sharing options...
Escape Posted February 3 Share Posted February 3 Also check the inertia switch. First step is to make sure there is power going to the pump. Unfortunately, the connector can't be reached as it sits on top of the tank. I would check/ bridge fuse 39, relay 12 and the inertia switch first. If the pump still isn't running, you can easily cut an access hole under the right rear seat to reach the pump. Much easier than dropping the fuel tank. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 3 Share Posted February 3 This thread will be useful for someone but the OP hasn't visited since just an hour after the thread was started. Quote Link to comment Share on other sites More sharing options...
