Popular Post Stellaghost Posted September 12 Popular Post Share Posted September 12 So went to use my shaper the other day and the shaft that supports the large drive gear sheared the flange and shaft are made from one piece of cast iron decided to make in steel to save a lot of wasted material I made components separately and welded together Completed holes drilled and tapped and new shaft installed, working like a good one again Regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted September 13 Share Posted September 13 A nice repair! What were you shaping on your shaper? Steve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 13 Share Posted September 13 43 minutes ago, steve200TDi said: What were you shaping on your shaper? Oooo, was it shapes? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 13 Share Posted September 13 Probably the hull of his model steam ship, 1/5 size. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 13 Author Share Posted September 13 4 hours ago, steve200TDi said: A nice repair! What were you shaping on your shaper? Steve Thanks Was setting up to cut material away from a piece of railtrack to make a small anvil, it sheared during the setting up process, had not even started cutting Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 13 Author Share Posted September 13 As you can see, working fine now 20240913_133421.mp4 Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 14 Share Posted September 14 Brilliant machines are Shapers, they only thing you can't make with them is money. 1 Quote Link to comment Share on other sites More sharing options...
