nige90 Posted February 20, 2007 Share Posted February 20, 2007 Hi, I want to rig up a plug in jump lead doofah and am after a suitable plug and socket. Thinking of the sort of thing used on fork lift truck batteries. Anyone done this and if so, where did you get the plug/socket ? Google and fleabay have failed me so far. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 20, 2007 Share Posted February 20, 2007 Have a look here http://www.torberry.co.uk About £5 each for 175amp Anderson Plug/Socket Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted February 20, 2007 Share Posted February 20, 2007 I used 35mm welder cable and Anderson Connectors 350amp Quote Link to comment Share on other sites More sharing options...
headhunter Posted February 20, 2007 Share Posted February 20, 2007 Have a look at x-eng.co.uk, it's run by simonr on here. He sells an X Jump which does the job I think you want to do. The plugs are known as andersen connectors (which x-eng use as well) and are sold by Durite in the UK. Durite sell through distributors which can be found on their website. Cost around £10 per plug. John Quote Link to comment Share on other sites More sharing options...
western Posted February 20, 2007 Share Posted February 20, 2007 Anderson modular power connectors www.andersonpower.com from 50 to 350amps [sB350 are best for jump leads] got mine from my local vehicle electrical suppliers. Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted February 20, 2007 Share Posted February 20, 2007 andseron connector Quote Link to comment Share on other sites More sharing options...
nige90 Posted February 20, 2007 Author Share Posted February 20, 2007 Excellent, thanks all. So much easier when you know the name of the gizmo you're after ! Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted February 20, 2007 Share Posted February 20, 2007 cable Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2007 Share Posted February 21, 2007 I've also seen Dinse plugs/sockets from welders used, probably because they had them around but they will certainly take the current: Quote Link to comment Share on other sites More sharing options...
mattD110td5x Posted February 27, 2007 Share Posted February 27, 2007 Excellent, thanks all.So much easier when you know the name of the gizmo you're after ! Have a look at an older thread.... "one for you elecy people" ttfn Matthew Quote Link to comment Share on other sites More sharing options...
