Les Henson Posted September 28, 2005 Share Posted September 28, 2005 I looked at a S2A 109 SW today that has a wrecked radiator. The core seems to be identical to a 'normal' 2.25 series motor, but the header tank is twice the width. As these radiators seem to be very expensive, would it be ok to use a standard type as used in 2.25 engines, and will it be a straight swap? Ta in advance. Les. Quote Link to comment Share on other sites More sharing options...
Outrage Posted September 28, 2005 Share Posted September 28, 2005 I looked at a S2A 109 SW today that has a wrecked radiator. The core seems to be identical to a 'normal' 2.25 series motor, but the header tank is twice the width. As these radiators seem to be very expensive, would it be ok to use a standard type as used in 2.25 engines, and will it be a straight swap?Ta in advance. Les. Hi Les, i dont know if a 2.5 diesel runs hotter than a petrol but ive got a standard 2.25 rad serving my 12J engine which works just fine. probably not much help, but worth a reply Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 28, 2005 Share Posted September 28, 2005 I'd say anything LR that'll fit will work - my stock rad cooled the V8 OK so you should get away with it Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 29, 2005 Share Posted September 29, 2005 cant see why not, series rad is quite efective (if kept clean). i run a 200tdi through one with no probs at all Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 29, 2005 Share Posted September 29, 2005 the series 3 comes in two flavous; 3 and 4 core, the latter being for overseas marketswhere the eather was hotter than in UK. Go for the 4 core - you can never have enough cooling and thermostat if working will prevent undercooling anyways. Paddocks were doing special deal on rads a little while ago or if you want originality you could recorethe original but you knew that anyway. Quote Link to comment Share on other sites More sharing options...
Bomag Posted November 9, 2005 Share Posted November 9, 2005 I was quoted £200 to recore a series rad, with the early deep header tank. Luck was with me and a mate passed on a good rad that he had picked up at SOdbury for a fiver Got a 4core for the V8, I found the 3core struggled a bit, but it might of been because it was knackered! Quote Link to comment Share on other sites More sharing options...
PeterW Posted November 15, 2005 Share Posted November 15, 2005 the series 3 comes in two flavous; 3 and 4 core, the latter being for overseas marketswhere the eather was hotter than in UK. Go for the 4 core - you can never have enough cooling and thermostat if working will prevent undercooling anyways. Paddocks were doing special deal on rads a little while ago or if you want originality you could recorethe original but you knew that anyway. Paddock still have them... From www.paddockspares.com Series 3 4cyl '4 CORE' USUALLY £75.00 plus VAT CURRENTLY £58.72 plus VAT Cheers Pete Quote Link to comment Share on other sites More sharing options...
