selectcase Posted March 23, 2007 Share Posted March 23, 2007 I am nearly at the point of re-assembling my 200tdi engine , its had a re-bore, new pistons, shells etc and i was wandering what oil to use on the bearings,seals, bores etc during the re-build to help preserve it until i fit it and run it up if you see what i mean? ta will Quote Link to comment Share on other sites More sharing options...
Lewis Posted March 23, 2007 Share Posted March 23, 2007 Castrol Classic engines 5w30 is what we use at work Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 23, 2007 Share Posted March 23, 2007 Assembly lube - you should be able to get it from most engine reconditioners. Its like a molybdenum grease. Advantge with it is that being a grease it stays where you put it, where if you use oil and then dont run the engine for a few weeks it tends to drain down off the internals. Jon Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 23, 2007 Share Posted March 23, 2007 Definitely proper pre-lube as the engine will run dry for a few seconds until the oil gets round and under pressure. You could also crank it on the starter with fuel cut off switch disconnected until the oil pressure warning light goes out. This ensures that when it fires up, oil is circulated. Les. Quote Link to comment Share on other sites More sharing options...
selectcase Posted March 23, 2007 Author Share Posted March 23, 2007 Thanks for the advice i will get some cheers Quote Link to comment Share on other sites More sharing options...
nige90 Posted March 23, 2007 Share Posted March 23, 2007 I used a 50/50 mix of engine oil and STP on advice of a mate who's rebuilt many a rally car engine over the years. Sticks like the proverbial to a blanket. I also wound the engine over with the fuel cut off disconnected and without the glow plugs in till the pressure got up. And after putting them back in again cranked before reconnecting the cut off. So far, 600miles in it's running sweet. Quote Link to comment Share on other sites More sharing options...
jjojjas Posted March 23, 2007 Share Posted March 23, 2007 as said above, assembly lube. We used to take the plugs out to stop it firing then wind it up with the starter to get some oil around it, then start it properly running it up to full temp. Not sure if thats all strictly essential, but the guy who taught me is still building race engines and has a good rep for over 30 years. Jas Quote Link to comment Share on other sites More sharing options...
