JST Posted April 3, 2007 Share Posted April 3, 2007 Ok, my truck cab came with the timing 'played with abit' i am not sure how much of which elements were played with but what i am trying to do is to get it back to std setup so i have a datum to run from. i have put the diaphragm back to its original factory setting, you can tell as it has the needle marks on it from where the needle used to go on the profile. Smoke screw has gone ACW 1.5 turns and the star wheel is unchanged. at the moment, power is OK, she will pull 75/80 on the speedo which is 10% under. BUT she smokes alot on startup - black smoke which to me says unburnt fuel so suggestions? smoke wheel (sounds logical but it doesn't seem to have much affect) or star wheel? PS the only reason i understand any of it as White90 showed me how to adjust it first time when i was trying to get it to std, thank you tony. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 3, 2007 Share Posted April 3, 2007 Timing is as per the manual. Fairly straightforward. You can use a 3/8" drll bit instead of the factory timing pin on the pump. Is it black when WARM and off boost? If just on cold startup, it could be crankcase oil. Quote Link to comment Share on other sites More sharing options...
JST Posted April 3, 2007 Author Share Posted April 3, 2007 woops i go tthe topic wrong it should say setting the FIP to factory setup - sorry. i was thinking worn rings etc and the oil could be burning but she doesn't use any! Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 3, 2007 Share Posted April 3, 2007 woops i go tthe topic wrongit should say setting the FIP to factory setup - sorry. i was thinking worn rings etc and the oil could be burning but she doesn't use any! James, have you allowed for the fact that Tdi's always smoke at startup. They do also burn a lot of oil as a natural phenomena Quote Link to comment Share on other sites More sharing options...
JST Posted April 3, 2007 Author Share Posted April 3, 2007 yep, this one smokes a bit too much and thats even if you only stop and turn the engine off for a minute so i discounted the oil seepage on that account. i don't touch the accelerator on start up either. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 3, 2007 Share Posted April 3, 2007 I'd leave well alone it drives lovely a bit of smoke never hurt anyone my 300 does the same. ps the only way to get factory spec is to remove it and get Elctro diesel or similar o set it up on a test bed/calibration machine costs £150ish then you have to remove/refit it. result=car is gutless and uses same amount of fuel... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 4, 2007 Share Posted April 4, 2007 Indeed, when mine was reconditioned and I got it back it was awful ! Luckily Tony was on hand to adjust it for me Mo Quote Link to comment Share on other sites More sharing options...
JST Posted April 4, 2007 Author Share Posted April 4, 2007 problem is the MOT man aint that happy with it expect i will jsut had to adjust the throttle linkage prior to test Quote Link to comment Share on other sites More sharing options...
GBMUD Posted April 4, 2007 Share Posted April 4, 2007 problem is the MOT man aint that happy with it What it does at start-up is nowt to do with him is it? Make sure that the engine is well warmed up (properly, 1/2 hour minimum) before he tests it and it will fly through the emissions part of the test. You have seen mine. Always passes by a mile on the MOT though. Chris Quote Link to comment Share on other sites More sharing options...
JST Posted April 4, 2007 Author Share Posted April 4, 2007 Chris - agreed, but when i am driving the only time i notice any 'excess' (as in more than expected for a tdi) is on start up. Jase and Tim have both followed me recently and said its not smoking. therefore the only tell tale sign i have is smoke on startup. yet it fails the emissions test when fully warm, hence trying to find where it should be so i can adjust it to that (prior to?) for a test. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 4, 2007 Share Posted April 4, 2007 Back off the full fuel screw on the back for the mot. Mo Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted April 4, 2007 Share Posted April 4, 2007 Take it for an 'Italian Tune up'. Basically rag the nuts off it just before the test. Try some injector cleaner too (or the old type 'A' ATF fluid into the fuel filter.) Quote Link to comment Share on other sites More sharing options...
