Guest WALFY Posted May 7, 2007 Share Posted May 7, 2007 Since fitting my new bulkhead I purchased a new lower dash to fit the speakers to. The drivers side is great but on the passenger side the wiper motor sits in the way. I have some small spacers but don't do the trick. I then purchased some other speakers with bigger spacers and they still don't fit. Anyone got any ideas Quote Link to comment Share on other sites More sharing options...
simonb Posted May 7, 2007 Share Posted May 7, 2007 Since fitting my new bulkhead I purchased a new lower dash to fit the speakers to. The drivers side is great but on the passenger side the wiper motor sits in the way. I have some small spacers but don't do the trick. I then purchased some other speakers with bigger spacers and they still don't fit.Anyone got any ideas If you can still find them in a scrappy, late Vauxhall Cavalier door speakers will work as they have a deep rim round them allowing you to surface mount them on the lower dash padding. Maplin do a grill which is an exact fit... Quote Link to comment Share on other sites More sharing options...
JST Posted May 7, 2007 Share Posted May 7, 2007 fit them somewhere else............. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 7, 2007 Share Posted May 7, 2007 In a truck cab. With posh carpet as a headliner. There is no where else. There must be a factory solution cos the holes are there. Can't see miniture wiper motor fitted when the speakers are. Quote Link to comment Share on other sites More sharing options...
western Posted May 7, 2007 Share Posted May 7, 2007 My front speakers are in the normal place I upgraded to pioneer speakers & used the matching 10mm thick spacer rings, to prevent the spaeker & wiper motor touching. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 7, 2007 Share Posted May 7, 2007 I'll have to look at moving the motor the to avoid my problem. At the moment the motor completly blocks the hole where the speaker wants to go. Quote Link to comment Share on other sites More sharing options...
JST Posted May 8, 2007 Share Posted May 8, 2007 mine are mounted up in the headlining in my truck cab just above your head in the rear corners. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 8, 2007 Share Posted May 8, 2007 The proper land rover spacers are about an inch think, is that not enough Mark ? Mo Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 8, 2007 Share Posted May 8, 2007 My 110 CSW came with the spacer as standard, but you can't fit speakers with really big magnets on them, as they still interfere with the wiper motor. It's a pain as the bigger the magnet, generally the better the sound quality! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 8, 2007 Share Posted May 8, 2007 I'll take some pics and post them up. It could be that I have not mounted the motor in the correct position. After all it is a TD5 bulkhead in a 1984 motor. Will have to think outside the box now with ref fitting the motor to the b/head Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2007 Share Posted May 8, 2007 This workshop manual picture might help with correcting the wiper motor position. File0017.pdf Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 8, 2007 Share Posted May 8, 2007 My passenger side speaker has a wooden spacer fashioned by a previous owner.. It's approx. 1 inch thick.. Neil Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 8, 2007 Share Posted May 8, 2007 Here is the position of my motor. Do you think that the braketry from a TD5 motor will fit my motor? Or will a TD5 motor fit the cable of the older system. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 8, 2007 Share Posted May 8, 2007 ^^^^ that wiper motor is definately too close to the "hole", there should be an inch or so clearance to allow the back of the speaker in there. maybe the strap that holds it up needs re-adjusting? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 8, 2007 Share Posted May 8, 2007 I must admit that when I fixed it in position I just put it in what looked like a nice angle for the control rod. Will have to look at moving the bracket. If I get chance this weekend Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 8, 2007 Share Posted May 8, 2007 Here is a shot of my wiper motor in place but I don't have a picture of it's location with the lower dash in place and speaker removed..... Hope the picture helps you with location.... Neil Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 8, 2007 Share Posted May 8, 2007 Neil Thanks for that. Will take off the corner piece and see if I can move it without having to strip the whole dash Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2007 Share Posted May 8, 2007 we can have a look at it on Saturday as I'm heading to yours for the air cond pump. at least you can compare it to mine. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 9, 2007 Share Posted May 9, 2007 Ralph Your a star. Not only part numbers but a mobile model for all to look at. Better than Haynes manual of lies :D Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 9, 2007 Share Posted May 9, 2007 RalphYour a star. Not only part numbers but a mobile model for all to look at. Better than Haynes manual of lies :D Just don't let him do his male modelling bit.... Quote Link to comment Share on other sites More sharing options...
western Posted May 9, 2007 Share Posted May 9, 2007 Just don't let him do his male modelling bit.... take no notice of him [DJ] Quote Link to comment Share on other sites More sharing options...
