nobber Posted May 12, 2007 Share Posted May 12, 2007 im replacing the driving members on the back of my 90. the front ones went on ok but the back ones are different , they are shorter. the axle has discs on there so im not sure if its off a rangie or not. here is a pic of both driving members , the ones on there are the shorter ones (35 mil) as opposed to the new ones (50 mil). the half shaft has 24 splines on the wheel end and ten on the diff end. any ideas? Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 12, 2007 Share Posted May 12, 2007 Could be RR or D1 or Defender though as stock the RR & D1 tend to have mushroom headed shafts. The thinner drive member is used for alloy wheels. Is the PCD of the two drive members the same? I have a RR axle in the back of mine and it not only used imperial bolts but a smaller PCD for the drive member. Quote Link to comment Share on other sites More sharing options...
nobber Posted May 12, 2007 Author Share Posted May 12, 2007 Could be RR or D1 or Defender though as stock the RR & D1 tend to have mushroom headed shafts. The thinner drive member is used for alloy wheels.Is the PCD of the two drive members the same? I have a RR axle in the back of mine and it not only used imperial bolts but a smaller PCD for the drive member. whats a pcd? Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 12, 2007 Share Posted May 12, 2007 Sorry, Pitch Circle Diameter. this is smaller on the older RR member and prevented me fitting my original 90 members (which happened to be thick as well) to my RR axle until I modified them. Quote Link to comment Share on other sites More sharing options...
nobber Posted May 12, 2007 Author Share Posted May 12, 2007 they both looked the same but the new member (defender) was a really tight fit on the half shaft and the defender gasket was a tad small for the old member. Quote Link to comment Share on other sites More sharing options...
steve_a Posted May 12, 2007 Share Posted May 12, 2007 Trev, how did you modify them? I have set of RR rear shafts sat around that I was gonna use on my 90 as spares. but as you say PCD is different and the holes are smaller than the bolts I use on my current axle, which means hub threads will be different. I was gonna drop them into a machine shop to be sorted out until I found out about PCD, which made me think it was more than just enlarging the holes. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 12, 2007 Share Posted May 12, 2007 OK There are I think 2 types early (imperial) Drive flanges and Metric ones, the metrics are thinner and the bolt is different too. 90s use different again. I had a devils own jobbie when I built up a imperial RR Casing, and a ARB 24 spline shafts and Metric hubs imperial calipers, metric flanges and bolts. Its sort of mix and match, but they do look similar, 90 and RR stuff is very mixed as to changability. Best to identify the hubs. Does the end of the wheel stud have either a "Dash" or a "Trainagle" stamped into it ? Nige Quote Link to comment Share on other sites More sharing options...
nobber Posted May 12, 2007 Author Share Posted May 12, 2007 OKThere are I think 2 types early (imperial) Drive flanges and Metric ones, the metrics are thinner and the bolt is different too. 90s use different again. I had a devils own jobbie when I built up a imperial RR Casing, and a ARB 24 spline shafts and Metric hubs imperial calipers, metric flanges and bolts. Its sort of mix and match, but they do look similar, 90 and RR stuff is very mixed as to changability. Best to identify the hubs. Does the end of the wheel stud have either a "Dash" or a "Trainagle" stamped into it ? Nige i found this http://66.102.9.104/search?q=cache:yVYyYCA...;cd=1&gl=uk its a driving member from a 300tdi si it could just be a later defender axle. nige i will take a look tomorrow for the stamp , what does dash and triangle mean then? Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 12, 2007 Share Posted May 12, 2007 Trev, how did you modify them? I have set of RR rear shafts sat around that I was gonna use on my 90 as spares. but as you say PCD is different and the holes are smaller than the bolts I use on my current axle, which means hub threads will be different. I was gonna drop them into a machine shop to be sorted out until I found out about PCD, which made me think it was more than just enlarging the holes. I was fitting 90 members on a RR hub so for me it was just slot the holes with a round file till they fitted (the bolts being smaller and on a smaller PCD). Not a very bling soln but it worked Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted May 15, 2007 Share Posted May 15, 2007 My two cents... I have just had a CV joint go on my 90. I ordered an new CV joint and drive flange only to be sent the wrong parts (which i fitted and it screwed everything). Anyway, when paddocks sent me the right parts i noticed that the drive flange was thinner that the incorrect part. Are you saying the items you took off are different or that the new parts sent to you are, or both? Quote Link to comment Share on other sites More sharing options...
