the cleaner Posted May 21, 2007 Share Posted May 21, 2007 Hello, just after some advice about tyre sizes. Have currently got BFG Trac Edge 235/85 R16's on wolf rims but they're gettin a bit on the low side so will need replacement soon. I know they don't make these any more how close are BFG AT's to these. Also askin cos someone has offered me some 31x10.50 R15 AT's very cheap. How different is the overall tyre size gonna be i.e. will they fit?? will they change the handling/ride much??. Any suggestions of any othe rtyre that won't cost me an arm an a leg. Oh yeah and i do about 70/30 road/off road drivin. Would really appreciate advice as am a bit of a numpty when it comes to this stuff!! Quote Link to comment Share on other sites More sharing options...
western Posted May 21, 2007 Share Posted May 21, 2007 the 31x10.50 R15 Won't fit because the Wheels are 16 inch diameter so there's no way those tyres will go on the rim. I run BFG MT's 255/85R16 on the same wheels without any problems, or you could try the 235 version. BFG at's are more road biased then the Trac-Edge. looking at your 70/30 road/off-road use BFG AT's in 235/85R16 size would be fine. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 21, 2007 Share Posted May 21, 2007 31x10.50R15 is about 265/70R16 equivalent - so will be not as tall (31" or more likely about 30.7", while the 235/85R16 will be nearer 32") and a fair bit wider. I don't think AT's are much good in muddy conditions but as long as it is reasonably dry they are OK - may be a bit wide if you are in typical UK conditions - not wide enough in this part of the world (hint: fill in your profile so we know where you are!) Quote Link to comment Share on other sites More sharing options...
treebloke Posted May 22, 2007 Share Posted May 22, 2007 Hello, just after some advice about tyre sizes. Have currently got BFG Trac Edge 235/85 R16's on wolf rims but they're gettin a bit on the low side so will need replacement soon. I know they don't make these any more how close are BFG AT's to these. Also askin cos someone has offered me some 31x10.50 R15 AT's very cheap. How different is the overall tyre size gonna be i.e. will they fit?? will they change the handling/ride much??. Any suggestions of any othe rtyre that won't cost me an arm an a leg. Oh yeah and i do about 70/30 road/off road drivin.Would really appreciate advice as am a bit of a numpty when it comes to this stuff!! I have two sets of simex both 35/10.5/16 but one set is bigger than the other. They were bought at different times but have covered roughly the same amount of milage and same pressures. The difference is in the height which is probably 3/4 cms. Quote Link to comment Share on other sites More sharing options...
JST Posted May 22, 2007 Share Posted May 22, 2007 i would go with 235/85R16 BFG ATs. i have run 235/85s trac edges on my td5 for a while and luckily came across an almost new set to replace the current ones otherwise i would have gone for the ATs/ in my experience stick with BFG they make good tyres that last a long time. MTs would prob be a bit OTT, i ran the td5 on 255/85sR16 BFG MTs for the recent forum Pyrenees trip and they were far louder (as expected) but excellent in the clop compared to trac edges. If your mainly road miles with a little off roading then ATs. or even have a second set of cheap remoulds for off roading. if off roading accounts for 50% of your time in the vehicle then MTs may be a better bet. Quote Link to comment Share on other sites More sharing options...
q-rover Posted May 23, 2007 Share Posted May 23, 2007 Cooper 255.85x16 ST would be a good fit 7.50x16, 235.85x16, 265.75x16 are all OE fitment and roughly the same height. The difference is in the width. Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted May 23, 2007 Share Posted May 23, 2007 Another here vote for the Cooper S/T and crucially a tyre pattern that would suit your indended use perfectly. The S/T is the nearest thing there is at the moment to a Trac-Edge style on-off road tyre. More agressive than the BFG A/Ts, but not quite an M/T and I'm guessing cheaper than the BFGs Been using them for three years now on two different LRs without complaint. At the moment my Defender running 255s on Wolf rims. Quote Link to comment Share on other sites More sharing options...
the cleaner Posted May 24, 2007 Author Share Posted May 24, 2007 Thanks guys for all the help, it is much appreciated! One more question though, can anyone point me in the direction of a good tyre supplier/fitter that won't cost the earth near me, I live in Northwood, Middlesex. Cheers peeps. Quote Link to comment Share on other sites More sharing options...
