Mo Murphy Posted October 15, 2005 Share Posted October 15, 2005 Would my 265 wide tyres have been fitted to 7 inch rims or 8 inch when they were assembled new at Bronco ? Mo Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 15, 2005 Share Posted October 15, 2005 Would my 265 wide tyres have been fitted to 7 inch rims or 8 inch when they were assembled new at Bronco ?Mo Probably could be either but I would expect 265s to be fitted to 7in rims normally, unless somebody was going for the "fat boy" look Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 15, 2005 Author Share Posted October 15, 2005 Stephen, is there a way to check with the tyre still on ? Mo Quote Link to comment Share on other sites More sharing options...
siggy Posted October 15, 2005 Share Posted October 15, 2005 tape measure If you could drop off the wheel lay flat on the ground, lay straight piece of wood over the tyres measure tat distance then measure down to rim fom piece of wood turn over tyre and repeat second part to rim take first figure fully inflated tyre to ground and subtract the two other figures it should give the rim width Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 15, 2005 Share Posted October 15, 2005 tape measureIf you could drop off the wheel lay flat on the ground, lay straight piece of wood over the tyres measure tat distance then measure down to rim fom piece of wood turn over tyre and repeat second part to rim take first figure fully inflated tyre to ground and subtract the two other figures it should give the rim width Mo, your's are 7s Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 15, 2005 Author Share Posted October 15, 2005 Thanks siggy and Will, appreciate that. Would 285 wide tyres be ok on 7 inch rims ? Mo Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 15, 2005 Share Posted October 15, 2005 285s are about the same as 11.50s, 12.50s are fine on 8 inch rims so I should think 285s will be OK on 7s, though 8s might be better Quote Link to comment Share on other sites More sharing options...
JST Posted October 16, 2005 Share Posted October 16, 2005 according to BFG website 285 are best on min 7.5J Quote Link to comment Share on other sites More sharing options...
GBMUD Posted October 16, 2005 Share Posted October 16, 2005 Stephen, is there a way to check with the tyre still on ? It would be usual to have the size stamped on the rim Mo, ie., 16x7J where the 7J refers to the width in inches. Look on the inside of the mounting flange in the centere. 285s will fit on 7" but I would be inclined to used 8". It is also my own personal and very humble opinion that 285s are too wide for general off-roading, at least what I do, and I would prefer something narrower. I think my 255/85s are too wide but I can't find anything narrower without compromising sidewall height. Suggestions welcome. Chris Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 16, 2005 Share Posted October 16, 2005 Thanks siggy and Will, appreciate that. Would 285 wide tyres be ok on 7 inch rims ? Mo Mo, my Simex run on 7's (and they're 285s IIRC) and I've no issues. Also, 7's will pull the tyre in more making it a little taller. Quote Link to comment Share on other sites More sharing options...
jules Posted October 16, 2005 Share Posted October 16, 2005 But what Will did not say is there supose to run on 8" rims but very few bother Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 16, 2005 Share Posted October 16, 2005 I also know somebody who ran 33x12.50R15 on 7" rims (305 wide) on a Toyota and had no problems, though they looked a bit odd and I really wouldn't recommend it! At the other extreme I know somebody else who put 11.50s on 10" wide rims and they looked even more odd... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 17, 2005 Author Share Posted October 17, 2005 Ah yes Chris, I remember Bude all too well 12.5 wide mts and no grip I think I'll pass on these tyres, If they're supposed to be on an 8" rim. Thanks for your help chaps Mo Quote Link to comment Share on other sites More sharing options...
