Kev Baldwin Posted July 11, 2007 Share Posted July 11, 2007 From the MoabJeeper Site Good test and interesting reading. Kev Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 11, 2007 Share Posted July 11, 2007 At least Warn won it, but not by much. I have one of their winches Les. Quote Link to comment Share on other sites More sharing options...
pugwash Posted July 11, 2007 Share Posted July 11, 2007 I think the test lacked in a couple of places milemarker bought a new winch design- whcih was just stupid. They should have been told to bring a standard winch. T-max- the thimble on the string came out so they cancelled the test. That's silly because you aren't then testing the winch, you're testing the rigging. would have been nice if they had fixed the problems above, otherwise it's an interesting test. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted July 11, 2007 Share Posted July 11, 2007 Go the 'numbers' page and read just how close the EPi and the XP were This test has been out a little while now and it makes interesting reading. Also check out the reply from Superwinch where it mentions the real Warrantee (the biggest selling point mentioned for Warn) Quote Link to comment Share on other sites More sharing options...
Mark Posted July 11, 2007 Share Posted July 11, 2007 T-max- the thimble on the string came out so they cancelled the test. That's silly because you aren't then testing the winch, you're testing the rigging. I think if you are using rope, you should know how to splice it, so the thimble comng off the end really should be an issue, as it can then just be looped round and spliced into itselt. I would have thought that if you were savvy enough to be using the kit, you should know how to fix it 'in the field' too... Otherwise, it is quite interesting reading. I guess they were limiting themselves to electric winches, hence not using the milemarker hydraulic affair.... I havn't got as far as reading the install articles, but I do wonder if the battery/cable/charging setups were sufficiently similar to be compared? more reading required I guess... Mark Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 11, 2007 Share Posted July 11, 2007 Interesting, because those two are the ones I would be looking at if I ever went to an electric winch. Says a lot for the EPi that, as a budget unit, it was so close to one of Warn's premium ones. Quote Link to comment Share on other sites More sharing options...
kkk2 Posted July 11, 2007 Share Posted July 11, 2007 Interesting reading, I use a hydraulic in front and a e9 on the rear, I have to agree with everything said about the superwinch, it is really strong and the lower amp draw means I do not need a huge battery set up to work it Quote Link to comment Share on other sites More sharing options...
