landybear Posted July 13, 2007 Share Posted July 13, 2007 Guys, I know its a newbie question but my diff lock was working pukka after gentle persuasion then i went on holiday for 2 weeks come back and cant get the light to come on. The guy who had it before never used low range or diff lock which i guess is why it seized. How can i access and free/ clean the contacts to enable the diff lock to work. I can here it 'engaging' when diff lock lever is pushed across but no light, does this mean its not engaged?? I have checked the bulb!! Any help would be greatly appreciated. Many thanks Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 13, 2007 Share Posted July 13, 2007 Guys, I know its a newbie question but my diff lock was working pukka after gentle persuasion then i went on holiday for 2 weeks come back and cant get the light to come on. The guy who had it before never used low range or diff lock which i guess is why it seized. How can i access and free/ clean the contacts to enable the diff lock to work. I can here it 'engaging' when diff lock lever is pushed across but no light, does this mean its not engaged?? I have checked the bulb!! Any help would be greatly appreciated. Many thanks It is probably not engaging. First step is to lube and clean the linkages. Second would be adjustment if needed. The switch detects the actual engagement within the t. case. If it were dead, you simply replace. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 13, 2007 Share Posted July 13, 2007 I'd start with the switch, its probably f*ed! If it feels as if it is engaging then it probably is. Quote Link to comment Share on other sites More sharing options...
landybear Posted July 13, 2007 Author Share Posted July 13, 2007 OK, i am new to landrovers only had it a month and a bit so how do i get to the switch? its on the top of the t-box, yes/no? its a learning curve for me so please bare with me!! Quote Link to comment Share on other sites More sharing options...
JST Posted July 13, 2007 Share Posted July 13, 2007 its on top of the T box at the front just above where the front prop goes into the t box. is the diff lock working irrespective of what the light is doing? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 13, 2007 Share Posted July 13, 2007 The switch is a little plunger, usual procedure with any Land Rover part is to douse it in WD40 and keep prodding it till it frees off Option 2 If that fails is to hit it although being an electrical component you'll have to use the Land Rover special miniature electrical lump hammer Quote Link to comment Share on other sites More sharing options...
landybear Posted July 14, 2007 Author Share Posted July 14, 2007 Thanks for the replies guys, diff light is all working now thanks to a bit of cleaning and lubrication. It was caked in crud so now its all nice and clean to cake again. Atleast i know whats going on now!! Am learning!! Quote Link to comment Share on other sites More sharing options...
