slihp Posted July 24, 2007 Share Posted July 24, 2007 Hi all me again. my trailer warning light comes on once when i use the indicators and i dont have a trailer attached. i have the electrics and a tow bar at the back but have never used them. any ideas?? Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted July 24, 2007 Share Posted July 24, 2007 Mine does it when the hazards are used instead of the main flasher light - assume that was LR Standard. It also did it once in a major rainstorm when the Lucarse wiring threw a paddy and I lost about half my indicators. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 24, 2007 Share Posted July 24, 2007 I'm pretty sure my trailer light flashes once when i indicate, and always has done. Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2007 Share Posted July 24, 2007 That's correct, it should flash once when turning either direction then go out & with a trailer attached it should flash at the same speed as the vehicle one & with hazard lights on it should flash in unison whether a trailer is attached or not Quote Link to comment Share on other sites More sharing options...
GYM Posted July 24, 2007 Share Posted July 24, 2007 Hi allme again. my trailer warning light comes on once when i use the indicators and i dont have a trailer attached. i have the electrics and a tow bar at the back but have never used them. any ideas?? Nothing wrong. They are supposed to do that... Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 24, 2007 Share Posted July 24, 2007 Lucarse wiring threw a paddy New one to me. Should I take offense? Quote Link to comment Share on other sites More sharing options...
davie Posted July 24, 2007 Share Posted July 24, 2007 sounds like your trailer indicator work is working perfectly to me - did exactly the same on my 200 tdi disco and does same on my 2003 90 - guess i would be more worried if it didnt do that!!! Quote Link to comment Share on other sites More sharing options...
slihp Posted July 24, 2007 Author Share Posted July 24, 2007 i guss it is possible they have done that all the time and ive never noticed. my first 90 and only had it about 5 weeks. strange. thanks chaps!! Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted July 24, 2007 Share Posted July 24, 2007 Think it's just because on first flick the power will be sent to to trailer to test if theres one there and when it comes back blank the 90 just assumes it's not there. Quote Link to comment Share on other sites More sharing options...
slihp Posted July 24, 2007 Author Share Posted July 24, 2007 correct, i read the operating manual, when the key is turned to position 2 the the trailer circut is tested and then gose off. this is the case for most systems on startup. but i have never noticed the light coming on once when indicating. i guess i have just missed the initial flash. Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted July 26, 2007 Share Posted July 26, 2007 Just a note, mine doesn't flash once whenever the indicators are pressed, but the light works as it comes on for the Hazards. Quote Link to comment Share on other sites More sharing options...
