ROGUE TROOPER Posted July 26, 2007 Share Posted July 26, 2007 Are there 3 types? Series/Defender/RRC/Disco Disco 2/RR P38 Disco 3/RRS/RR Is there such an adapter as Series hub to RRS wheel Quote Link to comment Share on other sites More sharing options...
sgnas Posted July 26, 2007 Share Posted July 26, 2007 Yep, just like wheelspacers but a little more complicated. There were some sets on ebay that let you run "classic" Land rover wheels on a transit! In "think" D2 and D3 are the same PCD but the nuts/studs are different. You can get little inserts that you press into the holes to run D3 wheels on P38 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 26, 2007 Share Posted July 26, 2007 Freelander are different again and I am not sure about Freelander 2 20" Stormer alloys going on your Series, RT? Quote Link to comment Share on other sites More sharing options...
smo Posted July 26, 2007 Share Posted July 26, 2007 Does anyone know what the bolt patten and PCD's are for the above vehicles as i'm looking for new wheels at the moment Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted July 26, 2007 Author Share Posted July 26, 2007 Freelander are different again and I am not sure about Freelander 220" Stormer alloys going on your Series, RT? No 19" Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted July 26, 2007 Author Share Posted July 26, 2007 No 19" So I "could" fit a set to a RRC? It would be a pain to make them, maybe it may be an idea adapting the adapter plates and drilling/taping holes and fitting new studs? Quote Link to comment Share on other sites More sharing options...
Tonk Posted July 27, 2007 Share Posted July 27, 2007 Does anyone know what the bolt patten and PCD's are for the above vehicles as i'm looking for new wheels at the moment Series/Defender/RRC/Disco are 5 hole 16mm, 6.5" (165.1mm) pcd. 1 Quote Link to comment Share on other sites More sharing options...
smo Posted July 27, 2007 Share Posted July 27, 2007 Series/Defender/RRC/Disco are 5 hole 16mm, 6.5" (165.1mm) pcd. Thanks Tonk Quote Link to comment Share on other sites More sharing options...
SteveG Posted July 27, 2007 Share Posted July 27, 2007 So I "could" fit a set to a RRC? To fit L322 RR, LR3 and RRSport wheels to a P38a or Disco II you need adapeter rings for the hub and wheel nuts that have a collar to them. If wanting to fit L322 RR, LR3 and RRSport wheels to a Series, Defender, RRC, you'll need to make sure that the adapter has the correct hub diameter. IIRC Simmonites do them and they are something like 350 pounds a set. So plus alloy wheel nuts and you are looking at 400 UKP before you buy wheels. btw have you looked at the price of 19" rubber, it's not cheap when it comes time to replace. Cheers Steve Quote Link to comment Share on other sites More sharing options...
JST Posted July 27, 2007 Share Posted July 27, 2007 Steve, with the good deal Richard got on the alloys he wont mind the adapter costs!!! Quote Link to comment Share on other sites More sharing options...
