muddy Posted August 2, 2007 Share Posted August 2, 2007 Hiya, i am trying to 'turn' my 8 spokes by taking the centres out and reverseing them, i have ground the 4 welds out so that i can see a line down the middle where the centre meets the rim, i then tried hitting it with a sledge hammer before standing the back end on the jcb on it and it just wont budge, so what am i doin wrong? Any tips? are any spot welded or flush riveted or similer?? Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 2, 2007 Share Posted August 2, 2007 Grind until you can see a hairline crack all the way through the welds (you actaully need to grind into the rim slightly). When I did mine I then sat a large log into the centre to protect it from hammer marks, and then beat the cr@p out of it with a sledge hammer. They do move eventually! If the rims are second hand then they can be hard to get moving. Brand new rims are alot easier to get apart! Once you've separated them you need to weld up the grinder marks in the rim and linish to make good before you re-fit the centres. HTH Jon Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 2, 2007 Share Posted August 2, 2007 then beat the cr@p out of it with a sledge hammer ".....And that gentlemen concludes the Highly Technical and detailed expert report from the Forums Hammer Stig....." Nige Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 2, 2007 Share Posted August 2, 2007 ".....And that gentlemen concludes the Highly Technical and detailed expert report from the Forums Hammer Stig....."Nige My work here is done.......... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 2, 2007 Share Posted August 2, 2007 Quote Link to comment Share on other sites More sharing options...
Griff Posted August 2, 2007 Share Posted August 2, 2007 Gidday, After trying the grinder/bash it/grind it more/bash it again/bend the centre method on one rim, I found a local engineer with a BIG lathe and had the rest spun off. You still need to apply BFH but not as much and you don't cut into the rim. Quote Link to comment Share on other sites More sharing options...
muddy Posted August 4, 2007 Author Share Posted August 4, 2007 Cheers guys FBH prevailed, only 4 more to do now Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 4, 2007 Share Posted August 4, 2007 Hiya, i am trying to 'turn' my 8 spokes by taking the centres out and reverseing them, i have ground the 4 welds out so that i can see a line down the middle where the centre meets the rim, i then tried hitting it with a sledge hammer before standing the back end on the jcb on it and it just wont budge, so what am i doin wrong? Any tips? are any spot welded or flush riveted or similer?? As Jon said, a total PITFA of a job! The trick if your grinding is to cut a little below the ine of the weld and go a little into the shell. I found it was a case of grind, place log into the centre and beat with sledge hammer, check for hairline cracks and then repeat until cracks formed at all 4 welds. Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 4, 2007 Share Posted August 4, 2007 So having done this what sort of backspacing are peeps putting on the reversed rim? Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 5, 2007 Share Posted August 5, 2007 Trev, Mine are 6" backspacing. I run on series axles and this takes the tyre out nicely to fill standard 90 wheel arches. Jon Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 5, 2007 Share Posted August 5, 2007 So having done this what sort of backspacing are peeps putting on the reversed rim? Mine went out by about another inch. Basically as as far as you could go without reversing Quote Link to comment Share on other sites More sharing options...
