Anglo-Frenchman Posted August 5, 2007 Share Posted August 5, 2007 Hi, Further to my previous post about transfer box ratios, I have now been offered one which is supposed to be a 1.222 ratio. Having asked the seller for the serial number he came back with 29D0358. According to the Ashcroft, serial numbers begining with 29D are from V8 90 LT85 gearboxes and have a ratio of 1.192. Can someone (perhaps Mr. Ashcroft) what the position is and if this box will bolt straight onto my LT77. I would have thought that a ratio of 1.192 would be better than 1.222 but also there is the issue of age. I would have thought that this t/box might be older then the 1.222. thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted August 5, 2007 Share Posted August 5, 2007 it should fit just make sure you get the input gear with it. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 5, 2007 Author Share Posted August 5, 2007 Thanks Tony. I don't quite follow what you mean though about the input gear. I thought that the T/box was a complete assembly? Thanks, Ged Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 5, 2007 Share Posted August 5, 2007 The input gear goes on the gearbox output shaft and is removable through the PTO hole, you sometimes find people selling them without it which is not much use if you're changing ratios. Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 5, 2007 Share Posted August 5, 2007 FWIW I have a 1.192 in my 90 (though I think mine was ex RR). Bolted up fine replacing the 1.67. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 5, 2007 Author Share Posted August 5, 2007 Thanks very much for clarifying that. Trev, did you notice any significant improvement in the cruising speed to make the change worthwhile? Ged Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2007 Share Posted August 5, 2007 Ged, 1.192 & 1.22 is as close (0.03 difference) to make hardly any noticeable difference, I think the numbers were rounded up to make it easier. you could stick with the existing ratio & fit a GKN Overdrive. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 5, 2007 Author Share Posted August 5, 2007 Ta Ralph. I was interested in whether Trev had noticed much difference going from the 1.67 to the 1.192 to make the change worthwhile. With regards to the GKN, what is the improvement like? Is it like having the 1.22 or better? Obviously the GKN has the benefit of being selectable but it is a lot more expensive than €250 for the transfer box. Whats your opinion? Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 5, 2007 Share Posted August 5, 2007 Thanks very much for clarifying that. Trev, did you notice any significant improvement in the cruising speed to make the change worthwhile?Ged My changes were for other reasons. The 1.192 was fitted with 4.7 diffs to reduce the overlap between hi and low range and give acceptable onroad gears with a nice low lowbox. Graph shows speeds at 1000, 2000, 3000 and 4000rpm with 35" tyres. Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2007 Share Posted August 5, 2007 Ta Ralph. I was interested in whether Trev had noticed much difference going from the 1.67 to the 1.192 to make the change worthwhile. With regards to the GKN, what is the improvement like? Is it like having the 1.22 or better? Obviously the GKN has the benefit of being selectable but it is a lot more expensive than €250 for the transfer box. Whats your opinion? the GKN OD Ashcroft's not sure what that would be in Euro's. fitted mine over a weekend & love it. IIRC JST did a write up of his OD use but I can't find it. gives similar results to having the 1.222 ratio but with the option of not having to loose the existing ratio's of the standard system. Quote Link to comment Share on other sites More sharing options...
