Diesel_90 Posted August 18, 2007 Share Posted August 18, 2007 Hi, My dad has just bought a K reg 1993 300Tdi 90, with a LT77. The story goes that it is a genuine LR that was used as a promo vehicle. Its just got me thinking as to what gearbox it has got because the engine is in the correct position for a 300tdi with a R380. I thought it would be a disco box but the Hi-LO lever is in the correct place for a defender. Could it be a defender box with a disco shaft? what would the bell housing be? a disco one but its not the same pattern so maybe a longer defender LT77 one?. what rear main set up would it have, the same as the 200Tdi? Or could it be a 300tdi engine with a 200disco back plate and disco LT77 Bell housing with shaft?The latter seems to make more sense to me I didnt even know that LR made a 300Tdi on a LT77 untill my dad bought his, is this a rare thing? Dan Quote Link to comment Share on other sites More sharing options...
pigster Posted August 18, 2007 Share Posted August 18, 2007 isn't that two years before the 300tdi was released - not sure on me dates on this one but how can it be a 300tdi ???? Are there v belts on the front or the other type flat looking belts. Hi, My dad has just bought a K reg 1993 300Tdi 90, with a LT77. The story goes that it is a genuine LR that was used as a promo vehicle. Its just got me thinking as to what gearbox it has got because the engine is in the correct position for a 300tdi with a R380. I thought it would be a disco box but the Hi-LO lever is in the correct place for a defender. Could it be a defender box with a disco shaft? what would the bell housing be? a disco one but its not the same pattern so maybe a longer defender LT77 one?. what rear main set up would it have, the same as the 200Tdi? Or could it be a 300tdi engine with a 200disco back plate and disco LT77 Bell housing with shaft?The latter seems to make more sense to me I didnt even know that LR made a 300Tdi on a LT77 untill my dad bought his, is this a rare thing? Dan Quote Link to comment Share on other sites More sharing options...
Dave K Posted August 18, 2007 Share Posted August 18, 2007 Must be a year before the launch of the 300Tdi. Says the man with a 1994 300Tdi 110SW(with an R380). Can't you retro-fit a LT77 if you remove a stud from the bellhousing? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 18, 2007 Share Posted August 18, 2007 Can't you retro-fit a LT77 if you remove a stud from the bellhousing? Why on earth would any sane person want to do that? Quote Link to comment Share on other sites More sharing options...
Dave K Posted August 18, 2007 Share Posted August 18, 2007 Why on earth would any sane person want to do that? I didn't bring sanity into the thread! Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 YES it deffinatly is a 300Tdi and it the 2 previous owners say that it is 100% genuine! And its a 1993 oh and its got discs on the back EDIT: Date of 1st reg was 08/06/1993 Quote Link to comment Share on other sites More sharing options...
Dave K Posted August 18, 2007 Share Posted August 18, 2007 YES it deffinatly is a 300Tdi and it the 2 previous owners say that it is 100% genuine!And its a 1993 oh and its got discs on the back EDIT: Date of 1st reg was 08/06/1993 Got any pics? Which side is the air intake? Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 ill try and take pics later. we are 100% certain that it is a 300Tdi after sevral years of owning and messing with 2s and 3s. The air intake is all correct for a 300Tdi, to lift the bonnet and look at it everything looks as it should untill you try to reverse the thing then alarm bells start ringing Found some info on the net about engine numbers, 105xxxxxx Series III petrol 3528cc V810Hxxxxxx 90/110 petrol 2286cc 8:1 CR 10Jxxxxxx 90/110 diesel 2286cc 11Gxxxxxx Series III petrol 3528cc V8 (detoxed) 11Hxxxxxx 90/110 petrol 2286cc 8:1 CR (detoxed) 12Gxxxxxx Series III petrol 3528cc V8 (Australia) 12Jxxxxxx 90/110 diesel 2495cc 13Hxxxxxx 90/110 petrol 2286cc 7:1 CR 141xxxxxx Series II petrol 1997cc 146xxxxxx Series II diesel 2052cc 14Gxxxxxx 90/110 petrol 3528cc V8 151xxxxxx Series II petrol 2286cc 156xxxxxx Series II diesel 2052cc 15Gxxxxxx 90/110 petrol 3528cc V8 (detoxed) 19Jxxxxxx 90/110 turbodiesel 2495cc 236xxxxxx Series IIA petrol 2286cc (fitted to 88 inch airportable) 241xxxxxx Series IIA petrol 2286cc 8:1 CR 251xxxxxx Series IIA petrol 2286cc 7:1 CR 252xxxxxx Series IIA petrol 2286cc 7:1 CR 253xxxxxx Series IIA petrol 2286cc 7:1 CR 271xxxxxx Series IIA diesel 2286cc 276xxxxxx Series IIA diesel 2286cc 286xxxxxx Series IIA petrol 2286cc (Forward Control) 300xxxxxx Series IIA petrol 2625cc (Forward Control) 325xxxxxx Series IIB petrol 2286cc (Forward Control) 330xxxxxx Series IIB petrol 2625cc (Forward Control) 335xxxxxx Series IIB diesel 2286cc (Forward Control) 345xxxxxx Series IIA petrol 2625cc 361xxxxxx Series III petrol 2286cc 8:1 CR 5-bearing 364xxxxxx Series III petrol 2286cc 7:1 CR 5-bearing 366xxxxxx Series III diesel 2286cc 5-bearing 895xxxxxx Series III diesel 2286cc 3-bearing (fitted to 88 inch airportable for export) 901xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 902xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 903xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 904xxxxxx Series III petrol 2286cc 7:1 CR 3-bearing 906xxxxxx Series III diesel 2286cc 3-bearing 941xxxxxx Series III petrol 2625cc 951xxxxxx Series III petrol 2286cc 3-bearing (fitted to 88 inch airportable) 956xxxxxx 101FC petrol 3528cc V8 961xxxxxx 101FC petrol 3528cc V8 The Engine number on my dads is 16L<not shown above 00028(letter) any chance this would mean it was the 28th 300tdi? Quote Link to comment Share on other sites More sharing options...
Dave K Posted August 18, 2007 Share Posted August 18, 2007 The number's right (I've just been out in the rain to check) Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 confusing isnt it Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 18, 2007 Share Posted August 18, 2007 Why on earth would any sane person want to do that? The engine is further back giving better weight distribution and room in the engine bay. If you use a military LT77, first gear is 10% lower. IMO, the LT77 bad rep is unfounded. I had one with 300000 km behind a V8 and it shifted as well as the day it came off the factory floor. Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 done some more digging, the reg plate ends in KV Coventry, so maybe it really was owned by LR Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 ah, done some more digging! looked on here http://www.dingocroft.co.uk/vin_numbers.htm everything in the VIN is correct BUT this comes up "M = 1995 M/Y" BUT the log book says it was 1st reg was 08/06/1993 so i think it is pretty safe to say that it was a proto owned by LR lovely Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 Just got off the phone to dunsfold(very nice people). It was a test vehicle for the 300Tdi and for Disc brakes!(on rear of defenders) and the engine number does point to it being the 28th and the gearbox points to a defender LT77 with a disco shaft and bellhousing its also got ARB brackets on the front and rear axle and NO Axle numbers not sure of splines yet as its got alloy wheels but i will find out later this week Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 The pipe on the back of the intake manifold goes to the air box, anyone ever seen anything like this on a 300Tdi before? i havent R380 Gbox tunneling Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 18, 2007 Author Share Posted August 18, 2007 The pipe on the back of the intake manifold goes to the top of the inj pump and there is no pipe to work the acuator on the turbo seriously confused Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 18, 2007 Share Posted August 18, 2007 If you use a military LT77, first gear is 10% lower. Only those with a 51A prefix.... 1st & 2nd are lowered. Quote Link to comment Share on other sites More sharing options...
simonb Posted August 19, 2007 Share Posted August 19, 2007 The pipe on the back of the intake manifold goes to the top of the inj pump and there is no pipe to work the acuator on the turbo seriously confused That pipe on the manifold goes to the inj pump to sort out the fuelling as boost increases. On a production 300tdi, that plug is just a blank and the pipe is "T"ed into the pipe that connects to the waste gate actutaor on the turbo. You may not actually see the wastegate pipe as its "under and behind" the compressor housing - there is a spigot attached to the compressor housing to fed air into the wastegate actuator pipe. With "your" set up, boost for the injector pump is actaully measured after the intercooler, where as standard its measured at the compressor of the turbo before the intercooler. Either is ok, nothing to worry about. Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 19, 2007 Author Share Posted August 19, 2007 it seems a better idea to put it where it is Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted August 19, 2007 Share Posted August 19, 2007 Kind of O/T, but why would the fact it's on a Coventry registration indicate it could be a Landie test vehicle, surely they'd come wearing Elihu's plates, like the new ones always have "Bx00xxx" Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 20, 2007 Share Posted August 20, 2007 Kind of O/T, but why would the fact it's on a Coventry registration indicate it could be a Landie test vehicle, surely they'd come wearing Elihu's plates, like the new ones always have "Bx00xxx" Because Land Rove may not have registered it . It may have gone to a dealer in Coventry although Land Rover ran it for a long time mike Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 20, 2007 Author Share Posted August 20, 2007 ot sure if landrover registerd it but before i spoke to dunsfold that was the only other thing to back up the story of it being a gen vehicle. i now know for sure that the story and vehicle was genuine and apparantly if you write to a address in the back of LRO you can pay £25 and get a "build sheet" for a vehicle. is this correct? Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 20, 2007 Share Posted August 20, 2007 ot sure if landrover registerd it but before i spoke to dunsfold that was the only other thing to back up the story of it being a gen vehicle. i now know for sure that the story and vehicle was genuine and apparantly if you write to a address in the back of LRO you can pay £25 and get a "build sheet" for a vehicle. is this correct? Yes I did it once for a light weight I had. Paul Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 21, 2007 Author Share Posted August 21, 2007 ill have to find the address and send off for a build sheet Quote Link to comment Share on other sites More sharing options...
