Jon White Posted August 20, 2007 Share Posted August 20, 2007 Thought this might be of interest:- We all know that the disco 200Tdi doesnt match up very well to the defender gearbox. Here's what I did to make it fit better! Counter bore the 4x bottom bolt holes where the bolts go through to the ladder frame to take M10 x 80 socket caps. I used a 16mm butterfly drill for this (thanks Tonk) to flat off the bottoms of the holes to take the bolts. There are three existing blind holes in the bottom of the bellhousing that are not tapped. Drill and tap these M10 and fit studs to them. There is a stud at about 2 o'clock as you at the back of the engine that needs removing. Finally remove and discard the 2x dowel pins that would locate the disco bellhousing to the flywheel housing. Job done. Engine now bolts directly to the defender bellhousing, with no mods to the bellhousing, and no messing about swapping engine back plates over etc. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 20, 2007 Share Posted August 20, 2007 Don't you still lose one bolt where the clutch slave is? I suppose it's a trade off-between the amount of work needed to drill and tap the holes against changing the flywheel housing. If you are going to replace the crank rear seal while you are in there, then in reality it's drilling and tapping 4 x holes against undoing 6 more bolts to swap the housings. In the end I suppose it's what you prefer to do. Les. Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 20, 2007 Author Share Posted August 20, 2007 Les, Yes you do need to lose the one by the slave cylinder. I just hadnt got that far when I took the photo! I accept that changing the housing over is easier, but it isnt if you havnt got another housing to swap over! Mine was previously a V8 fitted via a conversion ring, so there was no housing available! Jon Quote Link to comment Share on other sites More sharing options...
MECCANO Posted August 21, 2007 Share Posted August 21, 2007 Top man!!! Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted March 7, 2009 Share Posted March 7, 2009 I realize this is an old post, but if you don't sink those 4 bottom bolts, will any transmission work with the bolt sitting above the lip of the flywheel housing? The pictures below are what I have, if thats any help. Thanks Thought this might be of interest:- We all know that the disco 200Tdi doesnt match up very well to the defender gearbox. Here's what I did to make it fit better! Counter bore the 4x bottom bolt holes where the bolts go through to the ladder frame to take M10 x 80 socket caps. I used a 16mm butterfly drill for this (thanks Tonk) to flat off the bottoms of the holes to take the bolts. There are three existing blind holes in the bottom of the bellhousing that are not tapped. Drill and tap these M10 and fit studs to them. There is a stud at about 2 o'clock as you at the back of the engine that needs removing. Finally remove and discard the 2x dowel pins that would locate the disco bellhousing to the flywheel housing. Job done. Engine now bolts directly to the defender bellhousing, with no mods to the bellhousing, and no messing about swapping engine back plates over etc. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted March 7, 2009 Share Posted March 7, 2009 No Quote Link to comment Share on other sites More sharing options...
disco_al Posted March 9, 2009 Share Posted March 9, 2009 all we did was swap the alloy flywheel housing from the n/a to the tdi block, fitted perfectly. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 9, 2009 Share Posted March 9, 2009 all we did was swap the alloy flywheel housing from the n/a to the tdi block, fitted perfectly. And in doing so loose the support that the 4 bolts that Rover deemed nessesary that went thro the bellhousing into the ladder frame. Quote Link to comment Share on other sites More sharing options...
