s2hotdog Posted August 21, 2007 Share Posted August 21, 2007 Hi all I thought that I had found all the bodges on my 90 - but tonight I found another! I am in the process of fitting a snorkle - so have been looking closely at my existing air box/filter set up and found this Not good is it I've had my 90 for over 2 and a half years like this ! not done many miles though thankfully or in that dusty conditions So I need a favour - what air box do I have thought it was a disco but not so sure have brought a disco filter and its was too long The existing measures 200mm 8 inches approx my air box measures 235 mm approx 9.25 inches - this is from the bottom rubber ring to where its screwed on More photos of what I have Mounting bracket I think its a TD airbox and filter - but not sure The thought of going into a car factors and explaning to a spotty kid what I want is not that appealing when he asks me what it came off ............... So cheers for any help or a confirmmed measure would be great Forgive the carp phone photos Going to enjoy the rest of my beer now Steve Quote Link to comment Share on other sites More sharing options...
jameslwt Posted August 21, 2007 Share Posted August 21, 2007 I've got the same in my 300tdi defender. Well it looks the same, but too dark to go and measure up now! Hi allI thought that I had found all the bodges on my 90 - but tonight I found another! I am in the process of fitting a snorkle - so have been looking closely at my existing air box/filter set up and found this Not good is it I've had my 90 for over 2 and a half years like this ! not done many miles though thankfully or in that dusty conditions So I need a favour - what air box do I have thought it was a disco but not so sure have brought a disco filter and its was too long The existing measures 200mm 8 inches approx my air box measures 235 mm approx 9.25 inches - this is from the bottom rubber ring to where its screwed on More photos of what I have Mounting bracket I think its a TD airbox and filter - but not sure The thought of going into a car factors and explaning to a spotty kid what I want is not that appealing when he asks me what it came off ............... So cheers for any help or a confirmmed measure would be great Forgive the carp phone photos Going to enjoy the rest of my beer now Steve Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 21, 2007 Share Posted August 21, 2007 looks like a disco 200 tdi box from here. Need measurements to be sure. Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 21, 2007 Share Posted August 21, 2007 looks like a disco 200 tdi box from here. Need measurements to be sure. More than likely as the engine that its feeding is the same. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted August 21, 2007 Share Posted August 21, 2007 loks like a 200tdi defender due to where the bracket is mounte on the inner wing & also the T's on the airbox itself Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 21, 2007 Share Posted August 21, 2007 200TDi disco, same as mine. Quote Link to comment Share on other sites More sharing options...
Mark Posted August 21, 2007 Share Posted August 21, 2007 Doesn't look anything like my 200tdi disco one... Disco one doesn't have the extra pipe tee'd into the output, and the side entry is at the other end, about 2/3rds of the way along. Sorry, I don't know what it is, but I am pretty damned sure it is not a 200 disco filter. Mark Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 22, 2007 Share Posted August 22, 2007 There are two types of disco 200 air box and the filter is not interchangable. The later one has a pronounced flange at one end which is what I think you have. So you need the other 200 tdi discovery air filter. The Defender 200 air box is similar to yours but is the same length as the earlier disco box. Mo Quote Link to comment Share on other sites More sharing options...
sgnas Posted August 22, 2007 Share Posted August 22, 2007 Could be a 200tdi box with a TD filter fitted. TD filters are same construction and diameter but shorter. If you need it and Forum relay can get if fron Andover to chichester I probably have a spare TD filter box. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted August 22, 2007 Author Share Posted August 22, 2007 Thanks for all the replies chaps ! Lots of confusion - as to what in is then - not surprised - read on I did pop in to my local car part factors today and talked to a spotty kid and then the manager Tried the TD - what I have at the moment too small Tried Disco - too big Tried 110 + 90 TDI - too big After much looking at catalogs head scraching - looking at sizes on the internet Been told its not landrover at all but a japanise air box I can't believe it ! but thats what they told me - it dose have the drip outlet on it - very strange Got one on order anyway - as I said my landie is a bit of a bodge hopfully thats the last one I find - wish I spotted it earlier! Thanks again Steve Quote Link to comment Share on other sites More sharing options...
