Steve Warman Posted September 5, 2007 Share Posted September 5, 2007 Hi, I've just got my first 2nd hand defender and i need to get some spares for it. When I look at Paddocks and other websites they state that the part is for a certian range of vehicles that I assume is for the VIN. How do I decipher these numbers against my VIN? Thanks Steve Quote Link to comment Share on other sites More sharing options...
western Posted September 5, 2007 Share Posted September 5, 2007 Hi Steve, firstly Welcome to LR4x4.com, Please read the pinned info at the top line of the Defender forum, it'll help you get the best from the site. as for VIN numbers, they decode like this I'll use mine for reference (but will leave off the actual 6 digit serial number) & use * instead just replace these with the last 6 digits of your VIN number My 110 is a County SW 1989. SALLDHMB7FA****** SAL is the World Manufacturers identifier which in this case is Land Rover UK LD is the vehicle model range = Land Rover 90 or 110 H is the vehicles wheelbase in inches & = 110 ( a 90 will have a different letter code here, as will all the following depending on the actual vehicle) M is body type, Station Wagon 4 doors ( hardtop/van & pick up types again have different code letters) B is engine/fuel & size details type & in this case = 2.5 litre Turbo Diesel 7 is steering & gearbox -this = Rhd steering & 5 speed LT77 gearbox FA is the model build year & location of build this one is Solihull 1989 the last 6 digits ****** = the chassis production line serial number. one peculiar thing with 90/110 is the paint code it does not appear on the VIN plate rivetted to the brake pedal unit behind the servo, you'll have to ask a good main dealer which LR colour code applies to your vehicle. the other numbers on the VIN plate correspond to the Max gross weight including a Trailer & the front & rear max axle weights. hope that helps B Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 5, 2007 Author Share Posted September 5, 2007 Hi Steve, firstly Welcome to LR4x4.com, Please read the pinned info at the top line of the Defender forum, it'll help you get the best from the site.as for VIN numbers, they decode like this I'll use mine for reference (but will leave off the actual 6 digit serial number) & use * instead just replace these with the last 6 digits of your VIN number My 110 is a County SW 1989. SALLDHMB7FA****** SAL is the World Manufacturers identifier which in this case is Land Rover UK LD is the vehicle model range = Land Rover 90 or 110 H is the vehicles wheelbase in inches & = 110 ( a 90 will have a different letter code here, as will all the following depending on the actual vehicle) M is body type, Station Wagon 4 doors ( hardtop/van & pick up types again have different code letters) B is engine/fuel & size details type & in this case = 2.5 litre Turbo Diesel 7 is steering & gearbox -this = Rhd steering & 5 speed LT77 gearbox FA is the model build year & location of build this one is Solihull 1989 the last 6 digits ****** = the chassis production line serial number. one peculiar thing with 90/110 is the paint code it does not appear on the VIN plate rivetted to the brake pedal unit behind the servo, you'll have to ask a good main dealer which LR colour code applies to your vehicle. the other numbers on the VIN plate correspond to the Max gross weight including a Trailer & the front & rear max axle weights. hope that helps B Thanks for your reply, the pinned info is my next port of call. My VIN looks like the following (with the last 6 numbers removed. SALLDVBD7E****** So I have the SAL LD V as it's a 90 B body shape d 2.5l petrol 7 gearbox E Build location Does that sounds accurate? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted September 5, 2007 Share Posted September 5, 2007 1 digit missing should be a 17 digits in a VIN. most likely the missing digit is a 'A' so it would be SALLDVBD7EA which my info tells me is a 2.5 petrol,single carb, 90 3 door station wagon, 5 speed manual gearbox, right hand steering, built in the UK by LR @ Solihull about 1988 model year. Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 5, 2007 Author Share Posted September 5, 2007 I'll check again tomorrow, it was done by torchlight when I got home from work. Thanks Steve Quote Link to comment Share on other sites More sharing options...
western Posted September 5, 2007 Share Posted September 5, 2007 I'll check again tomorrow, it was done by torchlight when I got home from work.Thanks Steve no worries, all VINs conform to a worldwide 17 digit format, on another note which part of the UK are you in ? Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 6, 2007 Author Share Posted September 6, 2007 I'm from High Wycombe. I must update my profile a bit more Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 6, 2007 Author Share Posted September 6, 2007 Hi, My whole vin is SALLDVBD7EA****** How does this match against the part numbers specified on sites likes Paddocks? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted September 6, 2007 Share Posted September 6, 2007 Hi Steve, that makes more sense with the missing A added, it decodes as I replied above, it's the 'EA' bit which is the model year code that'll tell you if the parts are for your vehicle, most 90/110 parts are common across the range depending things like petrol engine, drum braked rear axle. Quote Link to comment Share on other sites More sharing options...
Suffolk Defender Posted January 30, 2016 Share Posted January 30, 2016 I know this is an old thread but i thought i would share this for those decoding their VIN. http://www.expeditiongear.co.za/cu5/Decoding-your-Land-Rover-VIN-Number.aspx Was tempted to copy and paste the info in case that page goes down, nothing worse than a dead URL when looking for information... Quote Link to comment Share on other sites More sharing options...
simonpelly Posted February 2, 2016 Share Posted February 2, 2016 With respect to paint codes, when removing the rear door trim from my 1997 Defender 110 300Tdi, found the computer print out of the build specification for the Landy including paint codes. Not sure if this is common practice or got lucky. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted February 3, 2016 Share Posted February 3, 2016 hi, found all the info to my landrover 90 1987 behind wiper motor cover after all these years it was still there, dd Quote Link to comment Share on other sites More sharing options...
