flatback90 Posted October 13, 2007 Share Posted October 13, 2007 where the hell do you mount the ariel for a cb when youre series is a full softop? any ideas? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 13, 2007 Share Posted October 13, 2007 in the wing? like an fm aerial? that's about the best position you've left, i reckon. Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted October 13, 2007 Share Posted October 13, 2007 in the wing? like an fm aerial? that's about the best position you've left, i reckon. that where mine's going (when I get round to it ) Quote Link to comment Share on other sites More sharing options...
Steve_M Posted October 13, 2007 Share Posted October 13, 2007 Mine was also on the wing in a lightweight with a full soft top. Quote Link to comment Share on other sites More sharing options...
jimfoo Posted October 13, 2007 Share Posted October 13, 2007 Mine's on a bracket off the windscreen bolt. I could also see off the front bumper. A friend has his on a bracket off the top rear door hinge, but it's a short antenna. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 13, 2007 Author Share Posted October 13, 2007 was thinking the wing also but its a 5ft whip so might hit a few pedestrians Quote Link to comment Share on other sites More sharing options...
twizzle Posted October 15, 2007 Share Posted October 15, 2007 was thinking the wing also but its a 5ft whip so might hit a few pedestrians I have two 5ft whip to go front an back bumpers makes beter coveridge TWIZZLE Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 15, 2007 Share Posted October 15, 2007 Dead centre of the bonnet. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 15, 2007 Author Share Posted October 15, 2007 so far fridges idea seems to be the most attractive next question is how do you sort out the ground plane issues? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 15, 2007 Share Posted October 15, 2007 Which ground plane issues do you mean? Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 15, 2007 Author Share Posted October 15, 2007 getting no range off the cb even after swr'ing the ariel was told it was due the fact landrover bodiess are aluminium? was told mount big piece of steel under the canvas between the hoops.......... Quote Link to comment Share on other sites More sharing options...
aljohnso Posted October 15, 2007 Share Posted October 15, 2007 I have mine mounted magnetically on the front bumper, works well, has never fallen off which is more than can be said for my wings! whe I first got it I thought it would fall off at the 1st bump and have been proved well and truly wrong Al. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 15, 2007 Share Posted October 15, 2007 getting no range off the cb even after swr'ing the ariel was told it was due the fact landrover bodiess are aluminium? was told mount big piece of steel under the canvas between the hoops.......... Well obviously mounting it on canvas is going to be a bit lacking in the ground plane department mounting it in the middle of your bonnet should be fine, aluminium is nice and conductive (although rubbish for mag-mounts ). Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 15, 2007 Author Share Posted October 15, 2007 hmmmm better look into this some more. the reason is i can only get a bout 1/2 mile range from a 4w set with a 5ft whip. was talking to a radio ham out here for the marconi celebrations he reckoned it was the lack of ground plane from the aluminium kinda struck me as strange coz ally conducts realy well. (they were talking to mid-america from ireland with only 24w) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 15, 2007 Share Posted October 15, 2007 If I want to get a long way I switch the 150W amp on Quote Link to comment Share on other sites More sharing options...
jericho Posted October 15, 2007 Share Posted October 15, 2007 hmmmm better look into this some more. the reason is i can only get a bout 1/2 mile range from a 4w set with a 5ft whip. was talking to a radio ham out here for the marconi celebrations he reckoned it was the lack of ground plane from the aluminium kinda struck me as strange coz ally conducts realy well. (they were talking to mid-america from ireland with only 24w) aluminium is a good conductor of electricity,but aluminium oxide is a poor one. Clean the underside of the bonnet (or whatever panel you choose) where the ariel bolts on back to clean shiney metal,re-atatch your ariel then paint the whole area straight away to prevent oxidisation. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 15, 2007 Author Share Posted October 15, 2007 aluminium is a good conductor of electricity,but aluminium oxide is a poor one.Clean the underside of the bonnet (or whatever panel you choose) where the ariel bolts on back to clean shiney metal,re-atatch your ariel then paint the whole area straight away to prevent oxidisation. hmmm didnt know that thanks! the bonnets gettin cluttered with the spare,highlift and now the cb ariel! Quote Link to comment Share on other sites More sharing options...
