white90 Posted October 21, 2007 Share Posted October 21, 2007 3/8th UNF apparently but I'd like some slightly longer than standard so I can utilise alternate locking methods for them on both diffs anyone have a pointer to a suppiler and more importantly know how long the bolts are as standard so I can order longer ones to suit nordlock rings or schnorr washers. plus 3/8 =9.85mm so the size in metric lines up M8 I think Quote Link to comment Share on other sites More sharing options...
ciderman Posted October 21, 2007 Share Posted October 21, 2007 Tony , I use GR Fastners in Avonmouth , they keep most sizes and tensiles in stock , heres their number 01179 381122 Quote Link to comment Share on other sites More sharing options...
white90 Posted October 21, 2007 Author Share Posted October 21, 2007 Cheers jase I've ordered schnorr washers and Nordlock rings I'll try one of each in each diff and see which if any is better I have found a cheap supply of schnorr washers the nordlocks cost 3x the amount Quote Link to comment Share on other sites More sharing options...
oddballrovers Posted October 21, 2007 Share Posted October 21, 2007 Hi Folks If we are talking about the same then Kam do them stronger and longer. Regards Ole. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 21, 2007 Author Share Posted October 21, 2007 searched: http://www.kamdiffs.com/service_parts.htm £42+vat for 20bolts seems steep though Quote Link to comment Share on other sites More sharing options...
SiWhite Posted October 22, 2007 Share Posted October 22, 2007 Tony, Could you post up the specs of what specs of bolts and washers, plus sources, that you use? I think others have had similar problems with ARBs and could use the info. Quote Link to comment Share on other sites More sharing options...
reads90 Posted October 22, 2007 Share Posted October 22, 2007 3/8th UNF apparently but I'd like some slightly longer than standard so I can utilise alternate locking methods for them on both diffs anyone have a pointer to a suppiler and more importantly know how long the bolts are as standard so I can order longer ones to suit nordlock rings or schnorr washers. plus 3/8 =9.85mm so the size in metric lines up M8 I think Tony Seris ones are the same thread but longer bolts What i had to use on my old 90 when my crown wheel eat the last lot Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 22, 2007 Share Posted October 22, 2007 Tony Seris ones are the same thread but longer boltsWhat i had to use on my old 90 when my crown wheel eat the last lot I'm sure I read somewhere these didn't have a high tensile strength - less than the shorter bolts used on 3.54 diffs anyway. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted October 23, 2007 Share Posted October 23, 2007 Tony, Happy to save you the postage if you want Quote Link to comment Share on other sites More sharing options...
