Where can I get one of these...?
bishbosh
Need to get my grubby paws on a couple of these:
Devon have them for £30 a pop. Anyone know of a better (read cheaper :D ) source? :unsure:
are they real albrights? (which i suspect they are copies) then you wont find cheaper.
personally i wouldn't fit cheap copies.
Thanks JU, for some odd reason not only did they not come up in any Google search I did for "Contactor" or "Isolator" or similar, it didn't even cross my mind to contact them directly!! :lol::ph34r:
Just had a very informative chat with Albright's tech guy.
He has confirmed that this contactor is a 100A continuous thermal current item. This concerned me a bit as my winch draws 375A at full load (in theory!). But as I am an electrikery thicko Mr Albright went on to explain that at 350A the contactor would be fine for about 2 1/2 minutes before needing a break.
Can't see me winching at stall load for 2 1/2 minutes!
He also confirmed Devon's pricing was appropriate so I get to to talk to Liz :D
BTW - Albright will be releasing a 350A jobbie early next year for "a bit more money"...... :huh:
Don't you just love electric winch ratings :blink:
"It wont get too hot as long as you don't use it for too long" :lol:
Would make a good electronically operated isolator....
I have a similar setup on my winch with an appropriately rated relay.
^^^^^^^^^^^Wot he said - electrical isolation of the winches without having gert fat cables running into the cab. (Well it is a Range Rover!!)
Albrights already do the winch control itself.
