Les Henson Posted December 30, 2007 Share Posted December 30, 2007 Mr Murphy blew his timing gear today Nige. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted December 30, 2007 Share Posted December 30, 2007 But did he fix it without telling anyone too ?? Neil Quote Link to comment Share on other sites More sharing options...
white90 Posted December 30, 2007 Share Posted December 30, 2007 Not the first time the timing has been an issue for Mo (slindon) bad luck hope it is fixed relatively easily/cheaply Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 30, 2007 Share Posted December 30, 2007 Hope he get it sorted for Friday, eh Mo Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 31, 2007 Share Posted December 31, 2007 Mr Murphy blew his timing gear today Nige. Hmmm..... Mr Henson been spying from the bushes again then? Quote Link to comment Share on other sites More sharing options...
JST Posted December 31, 2007 Share Posted December 31, 2007 He a no can do for Fri i am afraid Tim. hope you get it sorted soon Mo. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted December 31, 2007 Share Posted December 31, 2007 Oil has appeared in my ECU this morning. I am currently waiting for the RAC outside Halfrauds in Salisbury. D'OH! Chris Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 31, 2007 Share Posted December 31, 2007 Not only did I blow my gear through last night but I broke my timing belt yesterday whilst out laning in Essex and I didn't even make it to the first lane Still, **** happens. Uncle Les is going to fix it soon, I hope and I'll be able to get to James DRD at Bampton on the 20th. Mo Chris, that's a bugger ! Still new harness and a clean up should see you OK, good luck. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 31, 2007 Share Posted December 31, 2007 Dam,, Chris has beaten me to it,, was going to grass him up as well Best grass up Pugwash then,, all the dash light on, no rear pads etc,, and still got home,, just Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 31, 2007 Share Posted December 31, 2007 Chris and Mo, bad luck! That's the one thing I don't miss about Land Rovers - the breakages. Happily I have a Lotus that appears even more blessed with an ability to kill parts. Quote Link to comment Share on other sites More sharing options...
JST Posted December 31, 2007 Share Posted December 31, 2007 come on then TJ101 where did you and Puggy wander off to? any pics? a good day out? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 5, 2008 Share Posted January 5, 2008 Les came and waved his magic wand over my 90 today and It works now Mo Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 5, 2008 Share Posted January 5, 2008 That is good news. Why did you not do it yourself Mo, I know you are plenty capable? Chris Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 5, 2008 Share Posted January 5, 2008 Chris, I don't really like delving into oily bits in the engine myself and watching Les work, I wouldn't have had a clue ! However I have a better idea now. The belt didn't break but had had a dozen or so teeth stripped from it. The tensioner and the idler bearings were very, very worn. Les said that probably because of this wear in the idler and the tensioner the belt had jumped a tooth, then another, then a piston had hit a valve which then stripped the teeth from the belt. It would appear that a previously highly respected South Herts Independent Land Rover workshop who replaced the belt after the last breakage did not change or used a second hand idler and tensioner (the reason for the previous belt breakage was given by them as a seized tensioner) as these had far too much wear in them for the 15000 miles I've done since then. I was very impressed by Les' methodical approach to the work, attention to detail and cleanliness. I wouldn't hesitate to recommend him to anyone else ! Mo Quote Link to comment Share on other sites More sharing options...
