smo Posted December 31, 2007 Share Posted December 31, 2007 Purchased a 200Tdi defender today and its got a leaky injector pump, i've not identified where exactly its coming from - is it a common problem, do they have seals and gaskets that can be replaced?? Quote Link to comment Share on other sites More sharing options...
Bigwood Posted December 31, 2007 Share Posted December 31, 2007 Purchased a 200Tdi defender today and its got a leaky injector pump, i've not identified where exactly its coming from - is it a common problem, do they have seals and gaskets that can be replaced?? There are seals and gaskets that can be replaced. Not something that the DIY type of mechanic should realy consider I may add. An Injection pump is precision peice of kit that needs carefull striping and re-building. The most comon source of leaks I find is the the throtle shaft seals on top of the pump. This is underneath the arm for the cable. There is a bush in the top casing of the pump that wears alowing the shaft to move side ways creating a sorce of feul leak. Usulaly a town based vehicle that has a lot of speed changes in trafic. This can be resolved in situ quite easaly, the nasty leak is the drive shaft seal. This is behind the drive flange and if it fails it will cause fuel to run down the timing case cotaminating the cam belt. This will show at the wading plug, deisel driping out. This is a pump off job to fix unfortunatly, include a new cambelt in the price. I have seen a pump top cover re-sealed with instant gasket goo , my freind took two days to clean that out using ultrasonics ect, the bill was horific by the end. Nothings irepairable depending on the depth of youre pockets Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 1, 2008 Share Posted January 1, 2008 If the shaft seal is leaking and fuel is dripping out of the wading plug hole - you can replace the seal with the pump in situ. This thread covers how to do it - http://forums.lr4x4.com/index.php?showtopic=5260 Les. Quote Link to comment Share on other sites More sharing options...
smo Posted January 1, 2008 Author Share Posted January 1, 2008 It seems to be leaking from the back end somewhere, possibly between the outlet manifold and the main body? Quote Link to comment Share on other sites More sharing options...
perv Posted January 1, 2008 Share Posted January 1, 2008 It seems to be leaking from the back end somewhere, possibly between the outlet manifold and the main body? If it's between the ally housing and the cast lump called the "Head & Rotor Assembly" You know the part with the 4 outlets, It's an o ring seal but the pump will have to be removed for repair. Easy job though Regards Ash Quote Link to comment Share on other sites More sharing options...
simonb Posted January 1, 2008 Share Posted January 1, 2008 There are seals and gaskets that can be replaced. Not something that the DIY type of mechanic should realy consider I may add. An Injection pump is precision peice of kit that needs carefull striping and re-building. The most comon source of leaks I find is the the throtle shaft seals on top of the pump. This is underneath the arm for the cable. There is a thread with pics on how to fix this (written by yours truely) in the international forum around July 07. It was for a 300tdi but is applicable to all Bosch pumps. I'm sure someone will post the clicky link... Quote Link to comment Share on other sites More sharing options...
smo Posted January 1, 2008 Author Share Posted January 1, 2008 If it's between the ally housing and the cast lump called the "Head & Rotor Assembly" You know the part with the 4 outlets, It's an o ring seal but the pump will have to be removed for repair. Easy job though Regards Ash I'm not certain but i think thats where its leaking from. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted January 14, 2008 Share Posted January 14, 2008 Copy un paste http://www.forum-auto.com/pole-technique/s...sujet293129.htm into google. Get google to translate it into english and take a look. You will see that the Bosch VE he is playing with is off a VW, but this is not important as its the same jobby except for the black bit on the side, which yours will have the blanking plate on. As previously stated, its the large O ring that you need to replace. B) Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted January 14, 2008 Share Posted January 14, 2008 Because I'm collecting information like this; for Simonb .. " How to replace the throttle spindle seal on a Tdi Injection pump" is http://forums.lr4x4.com/index.php?showtopic=15329&hl= Cheers Quote Link to comment Share on other sites More sharing options...
