goaty Posted January 11, 2008 Share Posted January 11, 2008 Hi, Received my set of qt guards today and the front guard only has one bolt linking it to the top mounting bracket, whereas the rear has two. is this correct and how is that strong enough to take a hit??? thanks joe Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2008 Share Posted January 11, 2008 check here , if your very concerned talk to QT for their advice. but as far as I can tell it's correct. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 11, 2008 Share Posted January 11, 2008 I have not even bothered with the top plates on mine. I probably should... Chris Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 11, 2008 Share Posted January 11, 2008 I seem to recall mine on my old 90 only had one bolt because one hole lined up for fitting to mine and the other hole lined up for something else on a different type of vehicle. Didn't strike me as being the strongest bit of kit so I just have old faithful galvanised pan-cover on the front of the new 110. As a general rule I rarely reverse into rocks and the front one has enough scars to prove its worth Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 11, 2008 Share Posted January 11, 2008 yes that's correct just one bolt. It holds ok and takes a lot of smacks. Hit it hard enough and it will move, but you tend to have to really hit it to do this and ivariably your guard will be bent. Ask Tony, white90, he's done a couple like this Easy way to fit is to hold guard in place with a molegrip then you have two hands free to do up bolt. Cheers Steve Quote Link to comment Share on other sites More sharing options...
goaty Posted January 12, 2008 Author Share Posted January 12, 2008 ok, sounds like its the norm. Will stick it on for now but think i may drill and tap the second hole in just for an addtional feature. thanks for all replies. joe Quote Link to comment Share on other sites More sharing options...
