Mr Bean Posted February 4, 2008 Share Posted February 4, 2008 I have been reading through the history on here and i see references to people saying "vapour project". What does that phrase mean? Thanks Trev Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 4, 2008 Share Posted February 4, 2008 I have been reading through the history on here and i see references to people saying "vapour project".What does that phrase mean? Thanks Trev This thread might help, might not. Clicky Pete. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 4, 2008 Share Posted February 4, 2008 In your own mind you have an internally caged series defender with the cage on the outside, V8 petrol oil burner with megasquit, coiled leafer on 24-spline portal rangy axles, single Avon gel battery on split charge, 750/16 rims with 37" boggers, extended but still the same length as standard propshafts, standard diffs with limited slip lockers, a left hand snorkel fitted on the right - made by Safari mantec B&Q ltd, straight through stainless exhaust that rusts and exits through the left, right, and rear of the vehicle, tray back van side body with an electro-hydraulic winch at both ends and one in the middle - just in case. Les. Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted February 4, 2008 Author Share Posted February 4, 2008 I understabd now. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted February 4, 2008 Share Posted February 4, 2008 In your own mind you have an internally caged series defender with the cage on the outside, V8 petrol oil burner with megasquit, coiled leafer on 24-spline portal rangy axles, single Avon gel battery on split charge, 750/16 rims with 37" boggers, extended but still the same length as standard propshafts, standard diffs with limited slip lockers, a left hand snorkel fitted on the right - made by Safari mantec B&Q ltd, straight through stainless exhaust that rusts and exits through the left, right, and rear of the vehicle, tray back van side body with an electro-hydraulic winch at both ends and one in the middle - just in case. Les. :lol: :lol: You should be on the stage, Les... :lol: :lol: Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 5, 2008 Share Posted February 5, 2008 I'd understood it to mean a vehicle build project that originally began with lots of enthusiasm and grand ideas that gradually vaporised due to lack of time,enthusiasm, sufficient finances, workshop facilities etc etc. Bill. Quote Link to comment Share on other sites More sharing options...
letsgodisco Posted February 5, 2008 Share Posted February 5, 2008 In your own mind you have an internally caged series defender with the cage on the outside, V8 petrol oil burner with megasquit, coiled leafer on 24-spline portal rangy axles, single Avon gel battery on split charge, 750/16 rims with 37" boggers, extended but still the same length as standard propshafts, standard diffs with limited slip lockers, a left hand snorkel fitted on the right - made by Safari mantec B&Q ltd, straight through stainless exhaust that rusts and exits through the left, right, and rear of the vehicle, tray back van side body with an electro-hydraulic winch at both ends and one in the middle - just in case. Les. Weers tha get that fkr from? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 16, 2008 Share Posted February 16, 2008 Weers tha get that fkr from? smoking something possibly... Quote Link to comment Share on other sites More sharing options...
