Aggieturbo Posted February 18, 2008 Share Posted February 18, 2008 I've recently bought a 1988 110 SW fitted with 11 seats but only 5 seat belts (in the front 2 rows). Whats the best way to fit belts for the 6 inward facing seats (2 x 3 person benches)? I guess the anchor points need to be strengthened or the load spread over more than just one bolt, but as I don't know anybody else with this modification I'd welcome any ideas please. Quote Link to comment Share on other sites More sharing options...
western Posted February 18, 2008 Share Posted February 18, 2008 the late 300Tdi & Td5 110 11/12 seater uses these bracket for the rear bench seats Quote Link to comment Share on other sites More sharing options...
disco tony Posted February 18, 2008 Share Posted February 18, 2008 another way is to use retractable belts. The chap in the link will do a deal for multiple purchases. You would need to use a spreader plate. I've got six but not yet fitted them, time is precious! http://cgi.ebay.co.uk/Universal-Retractabl...7QQcmdZViewItembelts Quote Link to comment Share on other sites More sharing options...
Aggieturbo Posted February 23, 2008 Author Share Posted February 23, 2008 Thanks for the link and the pictures, I've had a look and will probably put them in as soon as i've sorted out another problem which has arisen and is a bit more pressing. See the new post if you think you could help with a power loss problem. Quote Link to comment Share on other sites More sharing options...
kamel Posted April 10, 2008 Share Posted April 10, 2008 I own a 110 CSW 2002 with the rear bench seats removed, but the brackets (number 20 in the picture above) are still installed. Is it safe to remove these brackets? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 10, 2008 Share Posted April 10, 2008 I own a 110 CSW 2002 with the rear bench seats removed, but the brackets (number 20 in the picture above) are still installed.Is it safe to remove these brackets? Yes but I would retain all the bits just in case you or the next owner ever needs them. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted April 10, 2008 Share Posted April 10, 2008 If you are going to fit seatbelts on sideways facing seats ( inwards facing ) the only type I would consider are full harness type fitted tightly to the occupants. Other types are virtually useless, in a front end shunt, and can cause as many injuries as they save Quote Link to comment Share on other sites More sharing options...
Aggieturbo Posted April 11, 2008 Author Share Posted April 11, 2008 If you are going to fit seatbelts on sideways facing seats ( inwards facing ) the only type I would consider are full harness type fitted tightly to the occupants. Other types are virtually useless, in a front end shunt, and can cause as many injuries as they save Have you done this? where did you get the bits? Quote Link to comment Share on other sites More sharing options...
