willfromsussex Posted February 20, 2008 Share Posted February 20, 2008 Silly question but how do the front seats come out, looks like they should slide right off the runners but they don't. Workshop manual mentions removing some bolt, can't find it. ta Quote Link to comment Share on other sites More sharing options...
Strega Posted February 20, 2008 Share Posted February 20, 2008 I think your seats are the same as the ones in my 86'. If they are there were two bolts at the front track that I removed then the seat slid right off. It does have to be dead level or will not go easily! Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted February 20, 2008 Share Posted February 20, 2008 I used to make the seat slides for Range Rovers in the early 80s and IIRC if they slide right off then there is something seriously wrong!. Again - IIRC, the slides are prevented from coming over-extending by 'dimples' in the ball tracks. This is because it becomes dangerously weak if the slide is adjusted too far forward since the seat-belt is anchored on the top section of the seat-slide. If the slide will disengage all the way, then I would suggest that it is damaged and dangerous. From memory, there are two bolts holding each slide down. If you slide the seat right forward you should then see the rear bolt inside each lower slide section, and likewise if you slide the seat right back you can get to the bolt that is inside the front of each lower slide section. They may be star drive socket bolts. Related memory: On the Series One (1949 - 80") which I used in the early 80's, the seat would slide right off. One day, in an accident* it did so, then dropped and wedged me tight against the steering wheel (no seat belts) so that my chest was pressing the horn and I couldn't get out (could hardly breath to tell the truth), Most embarrassing! TwoSheds * I had a new Lay-dee with me and we drove into the car park of a popular village pub. It was Summer and the place was heaving with lots of people outside in the 'beer-garden' which overlooked the car park. Finding no space, I saw an unkempt grassy bank and (with a smirk ) I engaged 4wd and drove slowly towards it. Unfortunately there was a low (but solid) retaining wall at the bottom of the bank that was totally obscured by overgrown grass and which just nicely caught the spring hangers... Well I got wedged as previously described and my passenger hit the wind-screen (not too hard - didn't even bruise), and I was left pinned with the horn blaring until some strong young men came over and helped me out. I can't remember now what she said or whether I saw her again - the mind has a way of blocking out trauma Quote Link to comment Share on other sites More sharing options...
steve_d Posted February 20, 2008 Share Posted February 20, 2008 On my 87 you slide the seat back to remove a hex socket, button head, screw in the front of each runner then slide it forward to remove 2 screws from the rear of each runner. The runners are sitting on ali spacers. Steve Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 20, 2008 Author Share Posted February 20, 2008 Hi, i can't believe i've spent another hour trying to get this seat out, there are no bolts that I can see, I'm thinking a 1987 car is probably different .I drifted out four roll-pins , this enabled the seat to go backwards out of the runners a bit, but then collided with the rear cargo floor, so no good. It would go no further foward than it would before. Maybe there is something wrong with my seat. I hope there is someone there who can step in and help here. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 21, 2008 Author Share Posted February 21, 2008 here is my other floor, showing the type of seat runner. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted February 21, 2008 Share Posted February 21, 2008 EDIT : err I might be about to make you fell silly but the seat comes out forwards once the roll pins are out and you have to hold the bar at the front up as if you were adjusting the seat as you run it fowards. Get me? LOL at two sheds, my passenger seat (of the type above) needs a little grease on the locking mechanism, sometimes after the seat had been moved to let someone into the back the front passenger would adjust the seat bachwards a little and it would seem to catch and lock and they'd think no more of it. Until I'd miss the lights or someone would slam on in front and my passenger would hurtle towards the dash and stop abruptly as the seat lock actually caught - these are the seatbelts built into the seat type remember so the belt would hold them in the seat but the whole seat would go from naught to brown trousers in a split second. They'd stop miles shy of the dash or screen of course but the look on their faces was always priceless They'd always look at me like I'd played a practical joke on them. Nowadays I te ll any passenger to give the seat a good shove to make sure it's locked... Oh just thinking aswell, there are some springs going from the seat to the seat base - they make the seat feel lighter when you're adjusting it - have you knocked those off? Just dotting the t's and crossing the i's Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 21, 2008 Author Share Posted February 21, 2008 Hi. yes i was holding the bar up and vigorously sliding the seat backwards and fowards once the roll pins were out, tried it witht he backrest upright, with the backrest tilted, etc, it was still hitting something. Its rare for something on a car to wind me up but I was getting really annoyed with this. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted February 21, 2008 Share Posted February 21, 2008 Sorry if I mislead anybody - the seat-slides I used to make were NOTHING like those in the picture... What year are they? I am guessing quite early? Quote Link to comment Share on other sites More sharing options...
Shackleton Posted February 22, 2008 Share Posted February 22, 2008 They're the first Range Rover seat bases, so from the beginning until at least '77 / '78 cause I've seen them in cars of that age. Will I'll have a gawp at mine in the morning. Either you have something jamming or mine are missing the phantom bolt you speak of Quote Link to comment Share on other sites More sharing options...
ChrisV8 Posted February 22, 2008 Share Posted February 22, 2008 Those are exactly like mine, have had mine out three times recently to change gearboxes. On mine take out the bolt through the seat slide at the front, disconnect spring underneath, lift locking handle and slide off backwards, mine came out without hitting the seat just heavy and awkward. the last time 16 year old grandson did it for me and had no probs. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted February 23, 2008 Share Posted February 23, 2008 Yeah was looking at mine today, sorry for the delay. Both of mine are out of the car along with the seat boxes and I've only removed the front roll pins so they definately come out backwards... Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 25, 2008 Author Share Posted February 25, 2008 finally got it out (daylight helped) there was a metal bracket to do with the auto-slide when tilt, which had come undone and got in the way of things. Once that was out of the way , it was tight but did come out (slid rearwards) gotta fix the bottom of the seat now, no rubber trampoline thingy left on it Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted February 25, 2008 Share Posted February 25, 2008 gotta fix the bottom of the seat now, no rubber trampoline thingy left on it It's called a seat cushion diaphragm and is Pt No MTC9931. I think these went discontinued while I still had my 2 dr back in 2000. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 26, 2008 Author Share Posted February 26, 2008 ho hum, in that case.... bring on the box of random springs! Quote Link to comment Share on other sites More sharing options...
Shackleton Posted February 26, 2008 Share Posted February 26, 2008 I had to change one in my late classic mini, strangely and from memory I don't think there's that great a difference in size. I'll do some measuring as soon as I get the chance, might be easily made to fit... Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted February 26, 2008 Share Posted February 26, 2008 Failing that I used on mine, a piece of inch and a half polystyrene type insulation (but this stuff didn't crumble as it was more plasticky???), cut to shape. It worked very well I have to say. Quote Link to comment Share on other sites More sharing options...
