JimAttrill Posted February 27, 2008 Share Posted February 27, 2008 I got some LED light bulbs and discovered that none of them work. This is because my Defender has postitive earth wiring, ie the positive is the outside of the bulb and the negative is the centre connection. This is true for the stop/tail lights, the side lights and the indicators. It looks as if I will have to rewire the whole lot, as although incandescent bulbs work either way, the LED bulbs require the correct wiring. Has anyone else noticed this problem with Defender wiring? Quote Link to comment Share on other sites More sharing options...
Dave K Posted February 27, 2008 Share Posted February 27, 2008 I got some LED light bulbs and discovered that none of them work. This is because my Defender has postitive earth wiring, ie the positive is the outside of the bulb and the negative is the centre connection. This is true for the stop/tail lights, the side lights and the indicators. It looks as if I will have to rewire the whole lot, as although incandescent bulbs work either way, the LED bulbs require the correct wiring. Has anyone else noticed this problem with Defender wiring? I had the same problem with my side lights. Reversed the spades in the connector using a small screwdriver. Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 27, 2008 Share Posted February 27, 2008 I got some LED light bulbs and discovered that none of them work. This is because my Defender has postitive earth wiring, ie the positive is the outside of the bulb and the negative is the centre connection. This is true for the stop/tail lights, the side lights and the indicators. It looks as if I will have to rewire the whole lot, as although incandescent bulbs work either way, the LED bulbs require the correct wiring. Has anyone else noticed this problem with Defender wiring? YES The LED's lights don't work on the rear side lights. Don't know how to fix this? Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 27, 2008 Share Posted February 27, 2008 I do now though... Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 27, 2008 Share Posted February 27, 2008 I hit this problem with one side light on mine Jim. What year is yours ?? Are the lights the complete plastic type with those small connectors. If so somebody, the factory, could have wired them wrong. Because they are a complete plastic bodied light it doesn't matter until you try to fit LED's. HTH mike Quote Link to comment Share on other sites More sharing options...
simonb Posted February 27, 2008 Share Posted February 27, 2008 I got some LED light bulbs and discovered that none of them work. This is because my Defender has postitive earth wiring, ie the positive is the outside of the bulb and the negative is the centre connection. This is true for the stop/tail lights, the side lights and the indicators. It looks as if I will have to rewire the whole lot, as although incandescent bulbs work either way, the LED bulbs require the correct wiring. Has anyone else noticed this problem with Defender wiring? Yep they are all like that, dunno why cos the body of the bulb should be earthed, typical LR...or is it the Prince of Darkness... Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 27, 2008 Author Share Posted February 27, 2008 My lights are the more modern ones with the bayonet plastic bulb holder which has a Murphy-proof connector in that you can't reverse the connector at all. The only way to get the connections right will be to cut the wires and reconnect them the other way round. We were considering selling bulbs at the workshop, but if it requires a complete cut and paste rewiring we will not bother. At least I now know that my Defender is not unusual. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 27, 2008 Share Posted February 27, 2008 That Murphy connector does come to bits. Well mine did and mins a 95 build. Not all LED's are need correct polarity mike Quote Link to comment Share on other sites More sharing options...
Dave K Posted February 27, 2008 Share Posted February 27, 2008 That Murphy connector does come to bits. Well mine did and mins a 95 build.Not all LED's are need correct polarity mike And mine's a 94! Rear lights worked OK, only needed to mod the fronts. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 28, 2008 Author Share Posted February 28, 2008 If I try to take it to bits, that's what I'll get, I reckon. I have found trying to take LR electrical connectors apart to be just about impossible this side of an anvil and sledgehammer All the leds I have, red white and yellow warn that correct polarity is required. Maybe I can find a connector lying about here and practice on it Quote Link to comment Share on other sites More sharing options...
Dave K Posted February 28, 2008 Share Posted February 28, 2008 If I try to take it to bits, that's what I'll get, I reckon. I have found trying to take LR electrical connectors apart to be just about impossible this side of an anvil and sledgehammer Very small flat bladed srcrewdriver, Jim. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 28, 2008 Share Posted February 28, 2008 Have a look here Jim Three way connector is what you will have http://wwww.vehicle-wiring-products.co.uk/...2/lights-2.html HTH mike Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 28, 2008 Share Posted February 28, 2008 I discovered this when I was selling LED bulbs. It seems to be a 300Tdi thing - though it may apply to Td5 too. It is quite true Jim, you can remove the contacts in the plug if you are careful with a tiny screwdriver and reverse them, no need for wire cutting. Cheers Chris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 28, 2008 Author Share Posted February 28, 2008 I'll give it a bash tonight ... This is just another one to add the list of crazy Defender things Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted February 28, 2008 Share Posted February 28, 2008 It's never straight forward when you want to mod something! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 29, 2008 Share Posted February 29, 2008 I've just tried the latest tower 21 watt equiv bulb, It's an SCC base. It's not polarity conceous [sp] mike Quote Link to comment Share on other sites More sharing options...
