Andy_LR90 Posted March 11, 2008 Share Posted March 11, 2008 Have a look and let me know what you think, has this been fitted with a lift kit?. I can't tell from the springs shocks etc as all are unmarked, by that I mean unlabled, they are browny rusty etc. The tyres are 205 R 16s Quote Link to comment Share on other sites More sharing options...
101sean Posted March 11, 2008 Share Posted March 11, 2008 Have a look and let me know what you think, has this been fitted with a lift kit?. I can't tell from the springs shocks etc as all are unmarked, by that I mean unlabled, they are browny rusty etc.The tyres are 205 R 16s Possibly, I fitted what were supposed to be standard bearmach springs to my 110 but reckon it's lifted it over an inch. 205's always looked small under a 90 anyway. You need to give the credit card a hammering and fit some new rims and bigger tyres Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 11, 2008 Share Posted March 11, 2008 I was given this measurement by Gwyn Lewis. A standard 90 has a distance between it's spring mounts of 260mm. So measure between your top and lower spring mounts and you'll have your answer. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Andy_LR90 Posted March 11, 2008 Author Share Posted March 11, 2008 Thanks Steve, just checked and I get 260mm between the spring mounts so I guess it's standard. I have got 5 of these 33 x 12.5 R16s to clean up and spray. They foul the radius arms on full lock so I'll need to adjust the lock stops. They fill the arches pretty well. Although if something inbetween the tiny ones and these monsters comes up on e-thief i may be tempted. Quote Link to comment Share on other sites More sharing options...
Adz Posted March 11, 2008 Share Posted March 11, 2008 What profile 205's? 205/50/16's would look tiny - IIRC 205/80/16 is the OE fitting for a 90. Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 11, 2008 Share Posted March 11, 2008 Thanks Steve, just checked and I get 260mm between the spring mounts so I guess it's standard. I have got 5 of these 33 x 12.5 R16s to clean up and spray. They foul the radius arms on full lock so I'll need to adjust the lock stops. They fill the arches pretty well. Although if something inbetween the tiny ones and these monsters comes up on e-thief i may be tempted. your 33's should be fine, if you are happy with steering lock once you've adjusted your stops. If not you can look at some wider offset rims. You'll probably need to trim the lower part of the plastic arches to stop them rubbing at full articulation off road. Or alternatively you can by 4 of these, ANR2938, to give you a 1/2" lift all round. They cost about five pounds each IIRC. If you want a 1" lift you can buy 4 more and fit them to top and bottom of your springs. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted March 11, 2008 Share Posted March 11, 2008 normal wheels and tyres always look small on defenders. Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 11, 2008 Share Posted March 11, 2008 normal wheels and tyres always look small on defenders. I forgot I had this pic... Steve Quote Link to comment Share on other sites More sharing options...
zulublue Posted March 11, 2008 Share Posted March 11, 2008 I am probably going to get shot down here, but when did LR move the fuel filler from behind the cab, or is this a mod to move the tank from underneath the drivers seat (if so nice job) Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted March 11, 2008 Share Posted March 11, 2008 I am probably going to get shot down here, but when did LR move the fuel filler from behind the cab, or is this a mod to move the tank from underneath the drivers seat (if so nice job) That came in with the TD5 .......................the tank is also in the rear as opposed to under the drivers seat........... Ian Quote Link to comment Share on other sites More sharing options...
Escape Posted March 12, 2008 Share Posted March 12, 2008 I forgot I had this pic...Steve Have been there as well: picie Front standard springs with 205R16, rear +4" with 37". Removing the arches also gives a totally different look. Filip Quote Link to comment Share on other sites More sharing options...
