storm99 Posted March 12, 2008 Share Posted March 12, 2008 and question nr2... i have a lot of play in the rear diff and its clunking every time i change gear or drive over a hole or bad road surface, how do i know which diff to order without removing the original first, as far as im aware there are various types with differenr number of splines...mine is a 1987 2.5N/A 90 Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 12, 2008 Share Posted March 12, 2008 That should be 10 spline as standard. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 12, 2008 Share Posted March 12, 2008 yup 10 spline. It takes 5 minutes to whip out a rear halfshaft to check. are you sure it's the diff? Quote Link to comment Share on other sites More sharing options...
muddy Posted March 12, 2008 Share Posted March 12, 2008 I would start by renewing the flanges on the ends of the halfshafts as these are prone to wear. Quote Link to comment Share on other sites More sharing options...
storm99 Posted March 13, 2008 Author Share Posted March 13, 2008 yup 10 spline.It takes 5 minutes to whip out a rear halfshaft to check. are you sure it's the diff? as sure as i can be, no play in the uj or the a frame ball joint, quite a bit of rotation on the propshaft where it joins the diff... Quote Link to comment Share on other sites More sharing options...
JST Posted March 13, 2008 Share Posted March 13, 2008 How much is quite a bit? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted March 13, 2008 Share Posted March 13, 2008 the only think that may be diffrent is if you truck seems slower than others the crown wheel and pin could have been changed(this is very unlickly tho, most trucks would never been tuched). Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted March 13, 2008 Share Posted March 13, 2008 Storm99. Have a look at a post I did a few weeks ago, the symptoms your describing are similar to mine, and by changing rear flanges and 1/2 shafts its much better. http://forums.lr4x4.com/index.php?showtopi...1&hl=flange Nic Quote Link to comment Share on other sites More sharing options...
Litch Posted March 14, 2008 Share Posted March 14, 2008 "It takes 5 minutes to whip out a rear halfshaft to check" I agreee 100%. Never rely on what SHOULD be there on a vehicle like a LR, take a shaft out and see what IS there and you will know for certain and make sure you order the correct parts. Also you can take the opertunity to check for wear on the splines (very evident if it is there). Over the years parts get swopped around and vehicles get upgraded, my 1986 ex-MOD 90 is fitted with 4-pinion diffs with 24-spline hafshafts so that is either standard fit for a MOD spec vehicle or an in-service modification as I am the first owner since release. Quote Link to comment Share on other sites More sharing options...
