rod Posted December 2, 2005 Share Posted December 2, 2005 I'm after and external gps aerial. Want to mount it to the roll cage, so any reccommendations? Advice? Where to buy etc? Thanks Rod Quote Link to comment Share on other sites More sharing options...
white90 Posted December 2, 2005 Share Posted December 2, 2005 Ebay loads and all cheap. I've had 3 different ones and they have all performed exactly the same. only changed when the Garmins changed then onto a PDA Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 2, 2005 Share Posted December 2, 2005 I've got one of the little Gamin mouse things. Works superbly. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted December 3, 2005 Share Posted December 3, 2005 Don't get the Garmin mushroom type - when it rains they let water into the co-ax! I just found that one out... Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 3, 2005 Share Posted December 3, 2005 As Tony said, get the cheapest you can from Ebay. Make sure it's USB and NMEA but don't be scared to buy from Hong Kong. The square black ones that I have can let water in, and have an internal battery that goes flat (so the LED goes dim) but it can be sorted easily. Performance wise, mine's not lacking and it's magnetic for cage-mounting. Quote Link to comment Share on other sites More sharing options...
western Posted December 3, 2005 Share Posted December 3, 2005 (edited) Try here GPS Antenna Edited December 3, 2005 by western Quote Link to comment Share on other sites More sharing options...
