k9unit Posted March 26, 2008 Share Posted March 26, 2008 what would you clean an intercooler with paul Quote Link to comment Share on other sites More sharing options...
Scotian Posted March 26, 2008 Share Posted March 26, 2008 Thinners Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 26, 2008 Share Posted March 26, 2008 you can get the proper stuff from LR (just been searching for it on microcat, but it only comes up as a reference number not a part number) and is expensive from LR or a B&Q special Quote Link to comment Share on other sites More sharing options...
western Posted March 26, 2008 Share Posted March 26, 2008 I used genklene last time my intercooler was cleaned, having it at work helped a lot LR specify D-solve see the tech bulletin below Quote Link to comment Share on other sites More sharing options...
JST Posted March 26, 2008 Share Posted March 26, 2008 petrol Quote Link to comment Share on other sites More sharing options...
RRX Posted March 26, 2008 Share Posted March 26, 2008 petrol +1 Quote Link to comment Share on other sites More sharing options...
nicks90 Posted March 27, 2008 Share Posted March 27, 2008 plenty of hot water and h/d kitchen degreaser liquid. shake it all about and rinse thoroughly. lovely and clean inside. refitted it and left the top hose off and gave it some revs. Turbo spooled up and blew all the remaining moisture out in seconds. easy peasy. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 27, 2008 Share Posted March 27, 2008 I use petrol. I put about 1/2 pint in, slosh it around for a while, tip it out and if it's black I do the same thing again until it comes out clean. I then use an old hair dryer blowing through one of the ends to remove any petrol vapour. It usually only takes a couple of pints to clean one out. Les. Quote Link to comment Share on other sites More sharing options...
