V8 90 JON Posted April 7, 2008 Share Posted April 7, 2008 Hi hope you can shed some light on a problem..... broke a cv joint at the weekend, striped the swivels down and as usual picked the wrong one first, however the half shaft on the un-broken side will not come out of the axel case ,it stops with what seems to be about 90 mm of shaft left inside ,it isnt broken cos i can feel it engage in the diff, if it makes any difference it's the off side one. also whats the strongest cv joint ive got a four pin diff and ashcroft half shafts. Quote Link to comment Share on other sites More sharing options...
Guest l90truck Posted April 7, 2008 Share Posted April 7, 2008 pull it harder Quote Link to comment Share on other sites More sharing options...
V8 90 JON Posted April 7, 2008 Author Share Posted April 7, 2008 pull it harder have tried very hard comes to a very definite stop Quote Link to comment Share on other sites More sharing options...
gus Posted April 7, 2008 Share Posted April 7, 2008 have tried very hard comes to a very definite stop Only these seal can stop the half shaft. Look inside axel, it is a clear and big tube. Probably your dif has broken and the half shaft is fixed to the pinion. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 7, 2008 Share Posted April 7, 2008 Shaft splines at the diff end distorted and jamming in the diff It will be "Fun" to get out You've got ARBs so you can get to it from tuher side, you wull have to maybe get a puller on it somehow (prob weld a lug and sacrifice the shaft, and pray it comes out withoiut damaging the ARB, if you can get a hydraulic puller this may do it gentler than massive "Shiftyerpig" shock loads not looking good is it ? Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 7, 2008 Share Posted April 7, 2008 also whats the strongest cv joint ive got a four pin diff and ashcroft half shafts. Someone more extreme will probably have a definitive answer but the Ashcroft ones are supposed to be quite good. I suspect the end of your shaft has twisted, in which case a whole lot of tugging and swearing is the order of the day. Quote Link to comment Share on other sites More sharing options...
V8 90 JON Posted April 10, 2008 Author Share Posted April 10, 2008 Ok got it out...... theres a bush in the end of the swivel and its dead...it and the half shaft have been attacking each other, any idea how hard it is to get the bush out? hammer or a press? Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted April 10, 2008 Share Posted April 10, 2008 Ok got it out...... theres a bush in the end of the swivel and its dead...it and the half shaft have been attacking each other, any idea how hard it is to get the bush out? hammer or a press? I use a bottle jack under my truck to do bushes usually, a little crude but certainly far cheaper than a press!! Quote Link to comment Share on other sites More sharing options...
