dantd5 Posted April 20, 2008 Share Posted April 20, 2008 I am wondering if anyone has used this tool and eventually any comments on it? Just wondering if I should buy it to help remove the visciuos Fan.... Tired of tips which leads to dead ends...... Quote Link to comment Share on other sites More sharing options...
silvio Posted April 20, 2008 Share Posted April 20, 2008 I bought them, and they are well done: no problems in removing the viscous fan. Not cheap, either... Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 20, 2008 Author Share Posted April 20, 2008 Cool.. the money is actually not the issue.. it is the functionability of tools that bothers me.. I guess I better get one NOW.... Thanks for the tip S..... Was it easy to get the fan off with them? Quote Link to comment Share on other sites More sharing options...
rick Posted April 20, 2008 Share Posted April 20, 2008 viscous fan spanners are pretty common and very cheap here. They are only pressed steel. Not sure on a TD5, but on a Tdi they are a left hand thread and it only takes a 'whack' with the palm of you hand to undo, or a slight blow on the spanner with a hammer. Quote Link to comment Share on other sites More sharing options...
101sean Posted April 20, 2008 Share Posted April 20, 2008 Man does not need an excuse to buy tools, get the credit card out now! Must get a set myself. BTW, if you want a laugh, look at the slogans on the Northern Tools website, every one true! http://www.northerntooluk.com/ My fave "A tool is measured by the size of its warning label" Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 20, 2008 Author Share Posted April 20, 2008 The more tools one owns the Better,,,,, independency is the word.. But that does not mean one should lavishly spend on them.... Which would you prefare.... sending the cash to the mechanic? or getting yourself equiped to the teeth....... Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 20, 2008 Author Share Posted April 20, 2008 viscous fan spanners are pretty common and very cheap here. They are only pressed steel.Not sure on a TD5, but on a Tdi they are a left hand thread and it only takes a 'whack' with the palm of you hand to undo, or a slight blow on the spanner with a hammer. They are right threaded on a td5,,, (absolutely sure on this)... well googling gave me just one on TD5s...... sometimes the cheapest way can be costly..... Tdi's have some similarities.. this one is exeptional.... Td5= 36mm tdi i guess are 32mm...... Adversely.. I will not challenge you Old hand...... Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted April 21, 2008 Share Posted April 21, 2008 or you could borrow one, take the viscous fan off, put it in the bin, fit an electric one and give the spanner back and not worry about your fan ever again mike Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted April 21, 2008 Share Posted April 21, 2008 BTW, if you want a laugh, look at the slogans on the Northern Tools website, every one true! "Sawdust. As close to Pot Pourri as a man can get." Awesome! Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted April 21, 2008 Share Posted April 21, 2008 I made one of these: which, in combination with a Halfords VC spanner, made it really easy... Quote Link to comment Share on other sites More sharing options...
nas90 Posted April 21, 2008 Share Posted April 21, 2008 Whats wrong with a hammer and sharp cold chisel? Works everytime for me! Spanners are a real pain to hold and then jolt with a hammer usually skinning your knuckles. Electric fans are rubbish. Viscous rules ok? Quote Link to comment Share on other sites More sharing options...
