Ben Jordan Posted December 20, 2005 Share Posted December 20, 2005 My Mrs has failed to get me the present that i wanted in time for Christmas, Maybe thats because i didnt make my mind up in time? Two weeks i thought would be plenty! Anyway as a back up present i am thinking about her getting me a Sumo track rod and drag link with the steering damper relocation kit. Where is the cheapest place to get these from? Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 20, 2005 Author Share Posted December 20, 2005 I have found the website www.sumobars.co.uk but can't seem to find the parts i need on the price list. has anybody else brought this kit before? Quote Link to comment Share on other sites More sharing options...
John_T Posted December 20, 2005 Share Posted December 20, 2005 I bought mine from QT Services. From what I remember at the time the prices were much of a muchness i.e. identical from whichever Sumo Bar agent you got them from. Nice bits of kit. Arguments will rage as to which are stronger (Sumo, Dan bars etc.) but the big advantage of Sumo bars is they do away with the time honoured problem of seized TREs and make track adjustment a doddle. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 20, 2005 Share Posted December 20, 2005 When i bent the std arm on the defender, i went for Sumo's via QT services,, good service,,and the same price as all the other suppliers !!! Saying that,, i did bent a sumo while at Bampton,within 6 months , there used to be a rumor, that they were warranted against bending,, but not the case, although they did do a deal on a replacment Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 20, 2005 Author Share Posted December 20, 2005 Im assuming they dont come with ball joints? What are the best ball joints to get? Quote Link to comment Share on other sites More sharing options...
John_T Posted December 20, 2005 Share Posted December 20, 2005 I got my TREs from Paddocks fitted with grease nipples. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2005 Share Posted December 21, 2005 Lemfroder ones are OEM available from exeter4x4 store 01392445262. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2005 Share Posted December 21, 2005 Tim had winched the bar on a hidden stump to bend his.... Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 21, 2005 Author Share Posted December 21, 2005 Is it better to have ones with grease nipples or without? Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2005 Share Posted December 21, 2005 personal choice easier to maintain with. I have a selection fitted to mine Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 21, 2005 Author Share Posted December 21, 2005 Im assuming i need 3? What are the combinations i.e. 2 x r/h thread, 1 x l/h thread? and the best place to get them because ive been told bad bad things about Paddocks. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2005 Share Posted December 21, 2005 exeter4x4store 01392445262 the'll post anywhere and are competitive. from the drivers seat the ones on your left are lefthand thread and on the right right handed. So that should be x2 left x2 right on the Rangie the drop arm has a seperate ball joint IIRC Quote Link to comment Share on other sites More sharing options...
Divster Posted December 21, 2005 Share Posted December 21, 2005 Mine are from QT also. I fitted them last year. The only problem I've had is that I managed to knock the grease nipple of the steering rod bar. It's still on the list of things to do Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted December 21, 2005 Share Posted December 21, 2005 Anyway as a back up present i am thinking about her getting me a Sumo track rod and drag link with the steering damper relocation kit. Unless Sumo have radically re-designed their damper re-location kit, I'd leave this well alone. It's badly designed and poorly made. I fitted one but ended up making my own when the Sumo one caused the end of my new OME damper to break off. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 21, 2005 Share Posted December 21, 2005 Tim's bar may have had more of a chance if he had the diff mounted bracket that restrains the bar at its mid length if it trys to bend. Alternatively, fit the QT diff guard that has this bracket built in. Having said that, the way Tim drives, there wasn't really much hope of it surviving....... Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 21, 2005 Share Posted December 21, 2005 Having said that, the way Tim drives, there wasn't really much hope of it surviving....... Love you too Charles !!! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 21, 2005 Share Posted December 21, 2005 I just have memories of Putham Lane and you going up it in mid air!! Red mist? Wot red mist!!!!!!! Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 21, 2005 Share Posted December 21, 2005 I just went to a Disco/RR type droparm/trackrod end arrangement since the drop arm ball joints kept dying every 6 months. I've got a generic Sumo-type bar although it's not exactly the same, bought from a bloke at a show, cheap. I ordered the damper relocation kit from QT Services, £20 delivered, but it doesn't fit my arm very well. I installed it vertical and packed it with cut-off bits of jubilee clip in the interim but it seems to be working its way down behind the arm slowly. Also, does this look like a sensible amount of thread showing on the TREs? There's 10 threads inside the bar. With the swan-neck and Ninety drop arm I couldn't get full right lock (drag link too long), now I've got full travel but I'm worried it's overextended. Thoughts? Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2005 Share Posted December 21, 2005 that looks like too much exposed thread for my personal taste/experience of bending them. there are approx 4 threads visble on all of my TRE's. ps those Hydraulic hoses look awfully vunerabble hanging down unthethered. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 21, 2005 Share Posted December 21, 2005 Much my thought re exposed threads, but what can I do to retain full steering in both directions unless I buy a new rod? The hoses were unclipped for the damper performance and at 10pm in subzero frost I didn't fancy tidying up - they're fine for the daily commute! Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2005 Share Posted December 21, 2005 is the drop arm centralised? Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 21, 2005 Author Share Posted December 21, 2005 I just went to a Disco/RR type droparm/trackrod end arrangement since the drop arm ball joints kept dying every 6 months. I've got a generic Sumo-type bar although it's not exactly the same, bought from a bloke at a show, cheap. I ordered the damper relocation kit from QT Services, £20 delivered, but it doesn't fit my arm very well. I installed it vertical and packed it with cut-off bits of jubilee clip in the interim but it seems to be working its way down behind the arm slowly. Also, does this look like a sensible amount of thread showing on the TREs? There's 10 threads inside the bar. With the swan-neck and Ninety drop arm I couldn't get full right lock (drag link too long), now I've got full travel but I'm worried it's overextended. Thoughts? Is this the Qt or sumo damper relocation kit? If its moving on the bar i suppose its not very good. Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 21, 2005 Author Share Posted December 21, 2005 Unless Sumo have radically re-designed their damper re-location kit, I'd leave this well alone. It's badly designed and poorly made. I fitted one but ended up making my own when the Sumo one caused the end of my new OME damper to break off. Kev have you got any pics of your current steering damper set up? Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted December 21, 2005 Author Share Posted December 21, 2005 Can anybody recommend a good damper relocation kit? I have herd that it is possible to relocate the damper using Defender parts would this be a better option? I have brought a new Qt front diff guard and it won't fit with the steering damper in it's current location hence the need to move it. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 21, 2005 Share Posted December 21, 2005 I have the QT clamp on a Sumo bar as shown by Turbo charger and have had problems with it in 2 years. I welded (well, not actually me ) a bracket to the chassis to pivk up the other end of the damper having cribbed dimensions from a defender. Quote Link to comment Share on other sites More sharing options...
