Graham Thomson Posted June 4, 2008 Share Posted June 4, 2008 I know it's not the biggest project for you total-engine-rebuild-boys, but the central silencer in my CSW 110 has two holes and I've decided to replace it (all the remaining parts have been recently replaced). Frankly for me it's about as brave as walking the plains of africa nekkid and covered in cow entrails. I've ordered the part and the gaskets required, question for you is "Do I need to also use some sort of exhaust cement and if so, what is the product called and where exactly does it go..............(this will ruin my nails for sure ...........). Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Dave K Posted June 4, 2008 Share Posted June 4, 2008 "Holts Firegum" does the trick, & put a straight silencer in there(no box) Quote Link to comment Share on other sites More sharing options...
Madcowz Posted June 4, 2008 Share Posted June 4, 2008 Sorry to hijack your thread but I have always used Holts GunGum for this. Should I instead be using Firegum as I notice that GunGum is for silencer repairs rather than gaskets. thanks. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted June 4, 2008 Share Posted June 4, 2008 We always use Wurth Exhaust Paste First Link i found Available from Here, Again, first one i found, but will be others Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted June 4, 2008 Share Posted June 4, 2008 Personally Graham, I would leave the centre box out entirely. I removed mine & had a straight through bit of stainless fitted. Negligible difference in noise levels, BIG difference in performance. Martin Quote Link to comment Share on other sites More sharing options...
Orange Posted June 4, 2008 Share Posted June 4, 2008 FireGum is usually used for overlapping joints rather than flanged joints. I don't ever remember seeing or using a gasket on an exhaust anywhere other than the manifold-to-head joint. I suppose it can't hurt to use a gasket, though... with a bit of fireGum for added surety. FWIW, I have had the exhaust apart several times on the 90 and to date haven't used either gum or gasket (other than on the head) and have achieved a complete seal every time. HTH Adrian Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 4, 2008 Share Posted June 4, 2008 Forget the exhaust box. Just fit a piece of pipe. I don't use anything on exhausts except the manifold gasket. Not had a problem ...Yet .... mike Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2008 Share Posted June 4, 2008 I fiited this non silncer pipe in Jan '07. here Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted June 5, 2008 Author Share Posted June 5, 2008 Well, the part has arrived (the proper exhaust part!)..........so roll on the weekend! Quote Link to comment Share on other sites More sharing options...
