FAO Tony Cordell
honitonhobbit
 Share
Tony,
Did you have any luck in your search for a Plasma friendly pulley block?
If not have you looked at this:
http://www.4x4wire.com/reviews/eoprecov/Dcp02020.jpg
They are just what the Doctor ordered - I have one here if you would like a look next week.
This is a better piccie:
http://www.beaver.com.au/images/Products/4...125B-_large.jpg
note the grease nipple. There is an R clip on the reverse side so the whole unit can be field stripped and zero play in the two halves
"The Black Rat 4WD off-road block has heavy duty one piece steel side covers for ease of use and have a gold passivated finish. The sheave is made from high grade cast Iron with a precision machined groove to accept 11mm wire rope with a pressure grease lubricated bearing. Minimum breaking strain 8,000kgs."
I can e-mail you over some piccies later or bring it with me on the 29th.
This is the "Thing" I use 99% of the time now, massively strong, swivelly hook thingy, greasable and about £80 from :
www.redpage.co.uk
Nige
Nige, those things are good but they need to be well maintained otherwise they become stiff. Also, the R clips are a PITA to deal with when you've got cold fingers.
 Share
