Guest noggy Posted June 7, 2008 Share Posted June 7, 2008 Would fitting a series 3 truck cab, to a landrover 90 possible? as, (yes im a cheapskate!) there are loads of series 2/3 truck cabs cheap, and 90 truck cabs are fairly expensive. has anyone done this? whats are the modifications? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 7, 2008 Share Posted June 7, 2008 No Noggy, not at all. The top of the windscreen is different. Mo Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2008 Share Posted June 7, 2008 you can use the rear upper panel [the bit with the windows in it] as Mo says the roof is completely different as the 90/110 front screen is taller Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 7, 2008 Share Posted June 7, 2008 How about if you fitted a S3 screen? Les. Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 7, 2008 Share Posted June 7, 2008 yep, and shorten the wiper blades (or fit series wipers)... Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted June 8, 2008 Share Posted June 8, 2008 so you could fit the series 3 screen and truck cab, and youd have no problems? Quote Link to comment Share on other sites More sharing options...
Muther Trucker Posted June 8, 2008 Share Posted June 8, 2008 you wouldnt be able to use the 90 screen bracket/hinges (if they are the same as a series 2a???), and you would have to remove the locating pins off the bulkhead Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 8, 2008 Share Posted June 8, 2008 You'd end up spending more to convert it than the difference in price between 90 and series truck cab and in my opinion it would look daft too ! Mo Quote Link to comment Share on other sites More sharing options...
