letsgetdirty Posted June 18, 2008 Share Posted June 18, 2008 Ive used the search engine and found information on how to cure propshaft angles after a lift. The problem is im really confused as to which prop i need?? wide angle? double yoke?? double cardon?? It was only supposed to be a 2inch lift on pro comps and heavy duty springs, The rear is about right, But the front has gone closer to 4inches? If you look at my picture on the post you will see the its quite high (its a bad pic, sorry) Its had time to settle, As a result the front prop is at quite an angle, So could someone enlighten me as to what to buy out of all the ones i mentioned at the start, Money is an issue to an extent. Also whats this business of removing the anti roll bar?? HOPE ALL ARE WELL!! Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 18, 2008 Share Posted June 18, 2008 Double Cardan is the design that removes the vibrations for high angles. Wide angle yokes stop the UJ's from rubbing at wide angles of operation. Once you need to put a DC prop on ideally you want to also make sure it has wide angle yokes. Don't put a Disco II DC prop on as it won't last and will cost you more in the long run. Really you need to sort out your springs and reduce the lift on the front to level it out. Anti roll bar can limit articulation off road, so most people take them off if they spend enough time off road and put up with more roll on road. With HD springs you've probably stiffened the ride enough not to notice lack of anti roll bars. Cheers Steve Quote Link to comment Share on other sites More sharing options...
The Badger Posted June 18, 2008 Share Posted June 18, 2008 Ive used the search engine and found information on how to cure propshaft angles after a lift.The problem is im really confused as to which prop i need?? wide angle? double yoke?? double cardon?? It was only supposed to be a 2inch lift on pro comps and heavy duty springs, The rear is about right, But the front has gone closer to 4inches? If you look at my picture on the post you will see the its quite high (its a bad pic, sorry) Its had time to settle, As a result the front prop is at quite an angle, So could someone enlighten me as to what to buy out of all the ones i mentioned at the start, Money is an issue to an extent. Also whats this business of removing the anti roll bar?? HOPE ALL ARE WELL!! You could use GW props, these work great on his massive lift... look at the pictures here - http://forums.lr4x4.com/index.php?act=post...f=9&t=27823 Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 Double Cardan is the design that removes the vibrations for high angles. Wide angle yokes stop the UJ's from rubbing at wide angles of operation. Once you need to put a DC prop on ideally you want to also make sure it has wide angle yokes.Don't put a Disco II DC prop on as it won't last and will cost you more in the long run. Really you need to sort out your springs and reduce the lift on the front to level it out. Anti roll bar can limit articulation off road, so most people take them off if they spend enough time off road and put up with more roll on road. With HD springs you've probably stiffened the ride enough not to notice lack of anti roll bars. Cheers Steve Thanks steve, So i need to combine a double cardon with wide angles yokes. sorry about before steve, caught me on a real bad day... Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 18, 2008 Share Posted June 18, 2008 Yes, but a decent one is going to cost about 200 pounds. If you don't need such a high left a set of OEM springs to give you a 1" lift with the winch would set you back about 35 pounds a pair and then you wouldn't need the propshaft. Cheers Steve Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 Yes, but a decent one is going to cost about 200 pounds. If you don't need such a high left a set of OEM springs to give you a 1" lift with the winch would set you back about 35 pounds a pair and then you wouldn't need the propshaft.Cheers Steve Can i fit wide angle yokes to the standard propshaft steve??? or anybody? ( RALPH!) Quote Link to comment Share on other sites More sharing options...
western Posted June 18, 2008 Share Posted June 18, 2008 wide angle yokes could be fitted to a standard length prop but again, it'll cost as both [at the same end] will have to be changed, I'd try some different front springs first as 4 inches up at the front must affect the driving characteristics of your 90, it's better to have a max of 1 inch difference [lower at the front] for example my 110 rides on HD OME springs, the front sits at 35 inches from ground to outer edge of arch flare & the rear is at 36 inches, it drives well & still gets me everywhere off road & no special prop mods as Steve says, drop the front so 90 is level or slightly nose down [about 1 inch] & see how it goes. Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 wide angle yokes could be fitted to a standard length prop but again, it'll cost as both [at the same end] will have to be changed, I'd try some different front springs first as 4 inches up at the front must affect the driving characteristics of your 90, it's better to have a max of 1 inch difference [lower at the front] for example my 110 rides on HD OME springs, the front sits at 35 inches from ground to outer edge of arch flare & the rear is at 36 inches, it drives well & still gets me everywhere off road & no special prop mods as Steve says, drop the front so 90 is level or slightly nose down [about 1 inch] & see how it goes. Right ill cost the yolks up and also see if i can raise the back another inch, If its too much cost wise i will get lower springs Thanks for help. Tris Quote Link to comment Share on other sites More sharing options...
white90 Posted June 18, 2008 Share Posted June 18, 2008 200? or 300TDI? if a 300 you can fit the TD5 Defender front prop this is wide angled already the rear can be helped with a dremmel to give more clearance Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 200? or 300TDI?if a 300 you can fit the TD5 Defender front prop this is wide angled already the rear can be helped with a dremmel to give more clearance 200tdi, DOH!! typical lol. ralph said i could fit double yokes but i need two each end, are they the same, so just order 4?? Quote Link to comment Share on other sites More sharing options...
rick Posted June 18, 2008 Share Posted June 18, 2008 Before you do anything, what are bump stop clearances on the front now ? i.e. when parked on a level bit of concrete, measure between the rubber bump stop (assuming stock bump rubber and not spaced down) and axle pad. If it's 115mm or under, you probably won't need a DC shaft. Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 Before you do anything, what are bump stop clearances on the front now ?i.e. when parked on a level bit of concrete, measure between the rubber bump stop (assuming stock bump rubber and not spaced down) and axle pad. If it's 115mm or under, you probably won't need a DC shaft. Give me 2 minutes! i will get me tape Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 Before you do anything, what are bump stop clearances on the front now ?i.e. when parked on a level bit of concrete, measure between the rubber bump stop (assuming stock bump rubber and not spaced down) and axle pad. If it's 115mm or under, you probably won't need a DC shaft. 170mm roughly maybe 180 from inside rubber to inside Quote Link to comment Share on other sites More sharing options...
rick Posted June 18, 2008 Share Posted June 18, 2008 170mm roughly maybe 180 from inside rubber to inside Could be a vibe or two with that with the yokes binding just a touch..... IIRC stock height is around 65-70mm...... Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 18, 2008 Author Share Posted June 18, 2008 Could be a vibe or two with that with the yokes binding just a touch.....IIRC stock height is around 65-70mm...... Not only a vibe but i didnt fit dislocation cones either! i found that out the hard way sunday night lol Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 19, 2008 Share Posted June 19, 2008 I have a selection of used springs of various poundages and lengths that you are welcome to try if you want to bring the front down a bit when you bring it over to be sprayed. At the back you can fit the rubber spring Isolators that are used on Discovery/Range Rovers, I think that one top and bottom gives approximately 1" lift although if it is dislocating at the rear then this might not be a viable option. Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 19, 2008 Author Share Posted June 19, 2008 I have a selection of used springs of various poundages and lengths that you are welcome to try if you want to bring the front down a bit when you bring it over to be sprayed. At the back you can fit the rubber spring Isolators that are used on Discovery/Range Rovers, I think that one top and bottom gives approximately 1" lift although if it is dislocating at the rear then this might not be a viable option. Thanks for that, Im having a play with the back today, I might try and find some more info on those isolaters you mentioned.I got some dislocation cones on there way lol have you heard off mike recently??? Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 19, 2008 Share Posted June 19, 2008 have a read here.. http://forums.lr4x4.com/index.php?showtopic=12063 This is a RR rubber isolator.. An easier way to measure suspension height over stock is between top spring mount and bottom. This should be 260mm on a standard 90 so you can work out your lift. Cheers Steve Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 19, 2008 Author Share Posted June 19, 2008 have a read here..http://forums.lr4x4.com/index.php?showtopic=12063 This is a RR rubber isolator.. An easier way to measure suspension height over stock is between top spring mount and bottom. This should be 260mm on a standard 90 so you can work out your lift. Cheers Steve Thanks steve, Thats real useful to me as im not sure what lift i have other than its a lot more than 2inches Quote Link to comment Share on other sites More sharing options...
