northernchris Posted December 30, 2005 Share Posted December 30, 2005 Can anyone tell me what half shafts would be fitted to a 87 rr 3.5 efi? front and rear. Chris Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted December 30, 2005 Share Posted December 30, 2005 Bit of a non-specific question really mate. They are basically the same right from the early days except that the drive flange is a fraction smaller allowing fitment of alloys. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 30, 2005 Share Posted December 30, 2005 So do all RR front 10 spline half shafts have 23 splines on the outer end? Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted December 31, 2005 Share Posted December 31, 2005 So do all RR front 10 spline half shafts have 23 splines on the outer end? Up to VIN EA305589 which is 88 MY, I believe the front shafts are interchangeable. Not sure of spline number but that does sound right. I'll know shortly as I have the job of stripping a front axle for the diff and shafts. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 31, 2005 Share Posted December 31, 2005 I think you'll find that on an 87 the front will be 32 outer or 23 outer and 10 inner, rears 10 spline prob mushroom head one piecers ?, neither shafts will have 24 spline inners in the diffs Nige Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted December 31, 2005 Share Posted December 31, 2005 (edited) Sorry Mark, didn't spot it was you asking, hope you are well. It's just the later ABS ones that have the extra splines isn't it, Nige Edited December 31, 2005 by DEANO3528 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 31, 2005 Share Posted December 31, 2005 Sorry Mark, didn't spot it was you asking, hope you are well.It's just the later ABS ones that have the extra splines isn't it, Nige ABS have speacial CVs, and I think the weaker 32 spline shafts in the front, this is late late stuff, the rear stub is different etc as are the hubs (metric) I know all this as I have a mix of it on mine to get the HD ashcroft shafts fitted (24/23) Nige Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 31, 2005 Share Posted December 31, 2005 Sorry Mark, didn't spot it was you asking, hope you are well. Fine thanks. Not too often in the RR section I must say, just popped in and spotted this thread. Reason I was asking is the axle on my 90 is ex-RR and I belive came from an '89 RR, no ABS, and I was wondering which CV's it would have. What I do know is shafts are 10 spline, CV's don't have integral stub shaft, it has the mushroom heads which have imperial bolts (9/16 spanner rather tha 17mm). Axle number is 18L00294A if that helps. I'm really interested to know if it would have the R606665 23 spline CV's or if not what needs changing to fit them, apart from the shafts obviously. Ever so slightly early new years greetings to y'all Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 31, 2005 Share Posted December 31, 2005 The swivel to casing - do they have 6 or 7 bolt fixings ? Nige Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 1, 2006 Share Posted January 1, 2006 The swivel to casing - do they have 6 or 7 bolt fixings ?Nige 7 Bolt Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 1, 2006 Share Posted January 1, 2006 Ok, In the looset terms you have a 7 bolt "Efi" axle, prob around late 1986 onwards. The diff will be a 10 spline, 100% ceratin. The halfshafts could be either late 23/24 (strong type) with a CV that is the same as the 6 bolt pre EFI "Imperial" axle, or, more lilly it will have the later much much weaker 32 10 spline half shafts plus the CV that has a small "Nose" on the outerside,. BOTH would have the 10 spline outer stub shaft with mushroom head. To convert you would need the 23/24 shafts, CVs and stub axles, as thesde have the bushes that accept the eralier CV, part number is something like 60xxxxx. You can use you old hubs etc Hope this helps, you;ll have to pull the stub axle off to see for sure Nige Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 1, 2006 Share Posted January 1, 2006 Thanks for that info Nige. As ever nothing's straight forward with a landrover Good to know I only need earlier stub axle (and shafts and CV's of course) to convert mine, assuming it turns out to be that later type. Shame the only spare axle I have in stock is off an '89 RR with ABS Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted January 1, 2006 Share Posted January 1, 2006 Spare axle in garage - pre 86 EFI type. You can come and get the bits you want and take them away for an agreed sum Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 7, 2006 Share Posted January 7, 2006 I might well take you up on that very kind offer, depends of the agreed sum Will PM you Quote Link to comment Share on other sites More sharing options...
