nickr Posted June 30, 2008 Share Posted June 30, 2008 I'm looking to get a set of modulars for my early ninety. I've got a set of part worn 265 x 75 AT BFG's which i wan to re use. I've read on other threads that these dont pair too well with Modulars when used heavily off road, but with my usage this should'nt be a problem. Once worn out I'll probably go the 255 route which seems to be a recommended option. My question is though, do I need to be careful with different offsets. Are modulars for a defender different to a discovery for example. Whats the prefered offset for this setup?. Also can anyone recommend a supplier? Most of the main suppliers do them! Thanks Nick Quote Link to comment Share on other sites More sharing options...
white90 Posted June 30, 2008 Share Posted June 30, 2008 Modulars in 16" come in Two offsets(backspace) 4.5" and 4.25" I have both here. I had 265/75/16s on 16/7 modulars with 4.25" backspace(offset) and they were fine Mine were MT's though AT's are very good tyres for road/mild off road work Exeter 4x4 store sell them at good prices/ maybe mailorder4x4 in Plymouth can help These are real measurements no guessing Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted June 30, 2008 Share Posted June 30, 2008 I have the 4.5" backspacing mods with around 33" tyres and a gwyn lewis kit and no rubbing what so ever. Although they have an extra 1.5" added to the width on the outside with the beadlocks. Oh, and they are fitted to a classic with a 70mm lift. This should mean on your defender, they should also not rub as your tyres will be around 33" tall. Although this will depend on what suspension setup you run obviously. Also, I paid about £32 per wheel I think from mansfield motors here in east anglia. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted June 30, 2008 Share Posted June 30, 2008 i use brookwells alot for my stuff thay know there stuff http://www.brookwell.co.uk/p/index give them a call to get price Quote Link to comment Share on other sites More sharing options...
nickr Posted July 1, 2008 Author Share Posted July 1, 2008 Thanks chaps, I'm still a bit confused about how many offsets are available. As well as White90 and others refering to 4.25" & 4.5" , browsing around, Scorpion refer to modulars having a 0 offset, and Devon 4x4 as a +8. Regards Nick Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted July 1, 2008 Share Posted July 1, 2008 Thanks chaps,I'm still a bit confused about how many offsets are available. As well as White90 and others refering to 4.25" & 4.5" , browsing around, Scorpion refer to modulars having a 0 offset, and Devon 4x4 as a +8. Regards Nick Offset is a weird thing. Actual off set is measured from the centre of the wheel. 0 is therefore directly in the middle. 8 is 8mm towards the outside of the wheel. Any other measurements are to help you visualise how deep the dish is. Quote Link to comment Share on other sites More sharing options...
MudAllOverIt Posted July 1, 2008 Share Posted July 1, 2008 As well as White90 and others refering to 4.25" & 4.5" , browsing around, Scorpion refer to modulars having a 0 offset, and Devon 4x4 as a +8. FWIW 4.25" and 4.5" is backspace (or should be) -- the distance from the inner edge of the rim to the wheel mounting face. So for an 8" wide rim for example -- 4.25" backspace = 0.25" positive offset; 4.5" = 0.5" positive offset. It gets a bit confusing cause people tend to use the term offset when quoting offset or backspace measurements -- but it's generally obvious from the dimensions whether someone is quoting backspace or offset figures. When fitting wider tyres you're looking for small positive or even negative offsets get some of the steering lock back. Another useful reference: Wheel Technical Info Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted July 1, 2008 Share Posted July 1, 2008 My experience is that the vendors rarely know what the offset is, and it does vary. Quote Link to comment Share on other sites More sharing options...
Big_John Posted July 2, 2008 Share Posted July 2, 2008 hmm, this may explain why one of my wheels appears to stick out further than the others .....will have to get the ruler out when I get home! I had thought they were all the same. They were on the 90 when I bought it, so no idea where they came from or if they were bought as a set. Quote Link to comment Share on other sites More sharing options...
