Ian M Posted July 6, 2008 Share Posted July 6, 2008 ive got a 200tdi discovery engine fitted in my 90, running the original lt77 gearbox and the original transfer box? is it possible to convert it to auto box? if so what is needed and from what vehicle? has anyone on here carried out this conversion before? ive had a search of the boards but turned anything up? Ian Quote Link to comment Share on other sites More sharing options...
white90 Posted July 6, 2008 Share Posted July 6, 2008 the auto backplate for the 200TDI is available from L/R as a Classic part Les Brock was looking into this may be drop him a PM Quote Link to comment Share on other sites More sharing options...
pat_pending Posted July 6, 2008 Share Posted July 6, 2008 I converted my 110 td to 200 tdi and auto. I used a modified v8 zf 4 speed and an m&d conversion plate. This does away with the need for the proper tdi auto back plate and box. I picked the bits up second hand. I don't know if they still produce them anymore, now that there are a lot of scrap Discos about. If you don't want to end up spending loads of money and huge aggro, find a 200 auto disco and you'll have nearly all the bits you need. I had to source all sorts of odd bits. The transmission on mine is about 4" longer than the manual so i had to re-drill the gear box mounting holes in the chassis. The n/s v8 auto box mount needed modifying as the v8 sits central in the chassis and the 4 pots are all offset to the n/s. Proper Disco bits should drop straight in, although i don't know if the Disco auto box is the same length so you may still have to move the transmission back. On a 110 the x member behind the seat box needed modifying as well, as the trans' is further back you can't get the h/brake drum off otherwise. I think you should be OK on a 90 though, even if the the trans' does have to go back. Lots of faffing about mix n match on the hi/lo-diff lock linkage as well. Lt 77 tunnel needs modifying, i got a 380 tunnel but that wouldn't fit either. I moved my rad back an inch or so at the bottom to get the standard oil cooler in without removing the bonnet landing panel supports. Had to get the front prop lengthened and the rear shortened. I also made up a new centre console to house the auto selector using an 07 defender cubby tray. Doable, yes. Time consuming, very. If you're interested i could get some pics up of mine. Well actually i couldn't, I'm a numpty with computers! but when one of my kids comes round I'm sure they could. Quote Link to comment Share on other sites More sharing options...
simon red90 Posted July 6, 2008 Share Posted July 6, 2008 wanted to do exacly the same to my 90. i ended up putting a 300 in, engine and box, as the parts are way easier to get than for the 200s. all fits in nicely. not yet finished tho. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 7, 2008 Share Posted July 7, 2008 Gave up trying to get all the bits Buy a 200Tdi Auto Disco use the bits you need and flog the rest ! Quote Link to comment Share on other sites More sharing options...
JST Posted July 7, 2008 Share Posted July 7, 2008 Les thats not really helping! i looked into this 12mths ago - 300tdi and auto straight seemed the easiest way of doing it, and ££££ for that therefore mean't i didn't! Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 7, 2008 Share Posted July 7, 2008 James, What you just said is what I meant with the 200Tdi !, just trying to get all the bits seperatly was just not happening and it was going to takes ages, as well as ££££££'s I'd go the 300 route as suggested IF I was to go that way Quote Link to comment Share on other sites More sharing options...
JST Posted July 7, 2008 Share Posted July 7, 2008 Les - it was tongue in cheek as similar to my answer, you know i Am in for winding mods up. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 7, 2008 Share Posted July 7, 2008 Quote Link to comment Share on other sites More sharing options...
will_warne Posted July 7, 2008 Share Posted July 7, 2008 the auto backplate for the 200TDI is available from L/R as a Classic partLes Brock was looking into this may be drop him a PM Tony, its unlikely unless things have changed. They may list the parts but getting hold of them can be problematic. When I did my conversion there was an unreliable source of 300 tdi backplates from Land Rover at a quite eye watering price (~ £300 IIRC). IMHO unless you must keep your engine (ie you have something like a 2.8tgv or recently rebuilt Tdi) then I'd swap out the engine+gearbox complete from a donor vehicle and sell on the old ones. There is a remarkable number of bits needed for an auto conversion (a list several sides of A4 long) and getting it complete saves a lot of time and money! Quote Link to comment Share on other sites More sharing options...
