MuddyMachine Posted July 9, 2008 Share Posted July 9, 2008 I am rebuilding my 1985 90 on to a 300 galv chassis, it now has a 300 bulk head and a td5 seat box. Using the R380 gear box, which tunnel pieces do I need or is it a case of making my own? Cheers Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 9, 2008 Share Posted July 9, 2008 Well I think you'll get away with just the bellhousing cover, which is wider than a LT77 one. I reckon the gearbox tunnel panel will still fit and match up to the seat box but I'm sure someone will confirm. You'll need to modify the floor panels a bit as well to match the different shape of the bellhousing cover. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 9, 2008 Share Posted July 9, 2008 ^^^^^ Yup, what he said. Quote Link to comment Share on other sites More sharing options...
MuddyMachine Posted July 9, 2008 Author Share Posted July 9, 2008 So do i need the 300 or the td5 pannel, or are they the same Cheers Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2008 Share Posted July 9, 2008 both used the R380 main gearbox with a long bellhousing. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 9, 2008 Share Posted July 9, 2008 Can you use an R380 tunnel on an Lt77 box ? I understand the matching bulkhead flange may foul the bell housing, anyone know by how much ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2008 Share Posted July 9, 2008 Well my 110 has a R380 on it's 200Tdi & it still has the original LT77 tunnel & bulkhead part fitted. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 9, 2008 Share Posted July 9, 2008 That doesn't help, Ralph Mo Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2008 Share Posted July 9, 2008 That doesn't help, Ralph Mo Oh well, Quote Link to comment Share on other sites More sharing options...
OilIT Posted July 9, 2008 Share Posted July 9, 2008 If youve got a 300tdi/td5 bulkhead and seatbox then you need the black plastic gearbox tunnel as opposed to the normal lt77 ally ones. With regard to clearance - there was a big conversation on this a year or so back - I think it was posted on the tech archive or somewhere similar - might be worth a scout around there...it was specific to the availability of all those defender bulkheads and what combinations could/would fit. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 9, 2008 Share Posted July 9, 2008 Thanks OilIT, I have the tunnel. I'll have a scout around. Mo Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2008 Share Posted July 9, 2008 from tech archive. bulkhead compatability Quote Link to comment Share on other sites More sharing options...
MuddyMachine Posted July 9, 2008 Author Share Posted July 9, 2008 from tech archive. bulkhead compatability Sorry link doesn't work Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 9, 2008 Share Posted July 9, 2008 Thanks Ralph, helpful as ever Mo Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2008 Share Posted July 9, 2008 Sorry link doesn't work Does now, dunno what went wrong Quote Link to comment Share on other sites More sharing options...
