Fiddler Posted July 29, 2008 Share Posted July 29, 2008 Would like to ask members for their input on a future project I'm planning - to fit rear wheel steer to my modified/Class1 trials car. The intended conversion will have a Defender front axle tube with the diff mounted in the opposite side so the steering arms on the hubs are facing to the rear as they would if on the front. The axle on the rear is currently fitted with a pegged diff running with Ashcroft h/duty 4.11 crownwheel/pinion set, ARB locker and ashcroft shafts. I am expecting to run a full hydrostatic independant steering system with a joystick control and an electrohydraulic self centering system operated by simple on off button - hopefully mounted on the steering wheel spinner/knob. The theory being that once the obstacle has been negotiated full concentratin can be applied to diff locks or fiddle brakes whilst the steering hand centers the rear wheels without having to lean out and do it by eye. I should also say that I am hoping to power the hydraulics with an electrical pump pack - does any body have any experience of accumulators, i.e. so the hydraulic pump can build up the pressure and store it so the pump can cut in & out? That is my basic plan and I open it up to the forum to pick it to pieces - nicely please! Cheers - Pete Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted July 31, 2008 Share Posted July 31, 2008 I think you'd find the joy stick adds too much complication. I'd be tempted to run an uprated pas pump, build yourself a drive through orbitrol and use a mechanical change over valve and have all the steering working off the wheel. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted July 31, 2008 Share Posted July 31, 2008 Sean at POS does a rear steer joystick with a self centre option built in if that helps? Quote Link to comment Share on other sites More sharing options...
Rizla 1 Posted July 31, 2008 Share Posted July 31, 2008 All trials drivers abroad run with joysticks and the scandinavians are the masters of them - Neil Whitford from the awdc has done this self centre stuff you could ask him Quote Link to comment Share on other sites More sharing options...
Fiddler Posted August 2, 2008 Author Share Posted August 2, 2008 Thanks for your replies so far. Could Dollythelw please reply again giving a link or contact details for POS steering people. Have been talking to Neil about this - Which cAN BE viewde oh the AWDC website forum. Have also been talking to Paul Leworthy @ venomprotruck.com - who's been telling me about a double ended ram he can supply for around £250 inc VAT Would be very interested in more details of european systems Cheers - Pete Quote Link to comment Share on other sites More sharing options...
dollythelw Posted August 2, 2008 Share Posted August 2, 2008 Here you go: POS LINKY Seans a really nice guy to deal with, knows his stuff in a big way Quote Link to comment Share on other sites More sharing options...
najw Posted August 2, 2008 Share Posted August 2, 2008 The last double ended rams I bought from Steerforth Sales in 2003 cost me £88.50 each. Quote Link to comment Share on other sites More sharing options...
simonr Posted August 2, 2008 Share Posted August 2, 2008 The last double ended rams I bought from Steerforth Sales in 2003 cost me £88.50 each. Just what I was going to say! Mine were a bit more expensive - but it was 4 years later. Si Quote Link to comment Share on other sites More sharing options...
SIMEXSLAVE Posted August 3, 2008 Share Posted August 3, 2008 I got all my rear steer parts from Psc in the states with the pound so strong you can get awsome rock crawler parts at a really good price and I use a electrically powered hydralic pump and a simple spool valve to steer. Quote Link to comment Share on other sites More sharing options...
Fiddler Posted August 4, 2008 Author Share Posted August 4, 2008 Does anyone know of a steering ram that has proximity sensors built in - and does anyone know the usual current draw on an average electrosolenoid valve - Cheers Pete Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted August 5, 2008 Share Posted August 5, 2008 Does anyone know of a steering ram that has proximity sensors built in - and does anyone know the usual current draw on an average electrosolenoid valve - Cheers Pete don,t know of rams with built in proxy switchs,i work with this type of gear all the time,you may or may not have seen the suzuki bodied rr chassis with rear steering in a recent t.o.r magazine,that had quite a simple but effective set up.to power it you could use a tail lift pump running continuously with a 2 way spool valve and a double acting ram mounted on the drag link,you could mount proxy swiches on a swivel which will show you when you are dead ahead,for hydraulic parts try harrier fluid power,they even have a ebay shop,very helpful and keen prices,if i can help any more just pm me,chris. Quote Link to comment Share on other sites More sharing options...
simonr Posted August 6, 2008 Share Posted August 6, 2008 What I've done (well, more or less, in a more complicated way), is use a handbrake cable to remote the movement of the ram to a nice sealed plastic box mounted somewhere dry(er). In the box you have two micro-switches. When the steering is central, neither switch is on. When you steer one way or the other one or the other switch is on. When you want to centre the steering, you connect each micro-switch to the valve which moves the ram in the direction which would switch that switch off. Thus, if the steering is off centre, it will move such as to centre it. It will over-shoot a bit and you will get some oscillation around the centre point which so long as your steering does not move too quickly will settle down. You need to position the switches close enough together to make the steering sufficiently central and far enough apart that it does no oscillate for ever - so it needs to be adjustable. Instead of micro-switches you could use proximity sensors which are a lot more reliable and less sensitive to moisture - a better bet long term. Micro-switces are easier to understand - which is why I suggested them initially. If you find you cannot stop it oscillating, you need to restrict the flow to reduce the speed of the ram. Si Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 6, 2008 Share Posted August 6, 2008 Would like to ask members for their input on a future project I'm planning - to fit rear wheel steer to my modified/Class1 trials car.The intended conversion will have a Defender front axle tube with the diff mounted in the opposite side so the steering arms on the hubs are facing to the rear as they would if on the front. The axle on the rear is currently fitted with a pegged diff running with Ashcroft h/duty 4.11 crownwheel/pinion set, ARB locker and ashcroft shafts. I am expecting to run a full hydrostatic independant steering system with a joystick control and an electrohydraulic self centering system operated by simple on off button - hopefully mounted on the steering wheel spinner/knob. The theory being that once the obstacle has been negotiated full concentratin can be applied to diff locks or fiddle brakes whilst the steering hand centers the rear wheels without having to lean out and do it by eye. I should also say that I am hoping to power the hydraulics with an electrical pump pack - does any body have any experience of accumulators, i.e. so the hydraulic pump can build up the pressure and store it so the pump can cut in & out? That is my basic plan and I open it up to the forum to pick it to pieces - nicely please! Cheers - Pete most of the amarican 4WS monster trucks use a rocker switch on the gear leaver i dont know if thay has self centering but i would have thort one of them would have come up with the idea and got it right. but if not simonr' idea seem the simplest to get to work Quote Link to comment Share on other sites More sharing options...
russ1 Posted August 6, 2008 Share Posted August 6, 2008 What I've done (well, more or less, in a more complicated way), is use a handbrake cable to remote the movement of the ram to a nice sealed plastic box mounted somewhere dry(er).In the box you have two micro-switches. When the steering is central, neither switch is on. When you steer one way or the other one or the other switch is on. When you want to centre the steering, you connect each micro-switch to the valve which moves the ram in the direction which would switch that switch off. Thus, if the steering is off centre, it will move such as to centre it. It will over-shoot a bit and you will get some oscillation around the centre point which so long as your steering does not move too quickly will settle down. You need to position the switches close enough together to make the steering sufficiently central and far enough apart that it does no oscillate for ever - so it needs to be adjustable. Instead of micro-switches you could use proximity sensors which are a lot more reliable and less sensitive to moisture - a better bet long term. Micro-switces are easier to understand - which is why I suggested them initially. If you find you cannot stop it oscillating, you need to restrict the flow to reduce the speed of the ram. Si This the kind of idea your talking about Si Quote Link to comment Share on other sites More sharing options...
simonr Posted August 6, 2008 Share Posted August 6, 2008 Yup - something like that! The way I'm actually doing it is using a Range Rover axle position sensor to measure the actual position - and a PIC controller to provide the same functionality as the micro-switches / end stops. It also gives servo steering to follow another similar sensor on the front when required. What sort of cable have you used? It looks much nicer than a hand-brake cable? Si Quote Link to comment Share on other sites More sharing options...
russ1 Posted August 6, 2008 Share Posted August 6, 2008 Pass!! There just pics i got from pirate 4x4, looks well done tho! Quote Link to comment Share on other sites More sharing options...
