draper40 Posted September 2, 2008 Share Posted September 2, 2008 Has anyone fitted a second fan to the intercooler on the 200tdi? It could be thermo controlled from an x-fan switch as it has 2 terminals? Pete Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted September 2, 2008 Share Posted September 2, 2008 Has anyone fitted a second fan to the intercooler on the 200tdi?It could be thermo controlled from an x-fan switch as it has 2 terminals? Pete Fans on intercoolers have been done with some success- useful when the vehicle is not travelling fast enough to get the benefit of air flow cooling but when you need the power... off roading! Why would you want it to be thermostatically controlled? - the requirement for intercooling of the charge air has nothing to do with overall engine temperature. It would be better to have it coming on when the turbo boost reaches a certain level- although you might just as well have it on a manual switch and then have it on when you need it. Quote Link to comment Share on other sites More sharing options...
draper40 Posted September 2, 2008 Author Share Posted September 2, 2008 I wasn't too bother about the therm thing, just thinking that the situations when you would need it would be when going slowly, so less air flow and therefore the engine will be hoter - plus it uses the other spade on the x-fan! What size fan would fit? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 2, 2008 Share Posted September 2, 2008 Pete, I've done it and yes it works You need a small intercooler sized fan. Mo Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted September 2, 2008 Share Posted September 2, 2008 Pete, I've done it and yes it works You need a small intercooler sized fan.Mo Mo- how much of a difference did fitting the fan to the intercooler make? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted September 2, 2008 Share Posted September 2, 2008 why use the other terminal on the switch? They're for different switching temperatures. As has been said, intercooler cooling has very little to do with engine/water temperature. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 3, 2008 Share Posted September 3, 2008 Mitsubishi's have an intercooler fan mounted between the bonnet and cooler. They look like the ideal size to go on a 200/300TDi one. Les. Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted September 3, 2008 Share Posted September 3, 2008 TD5 Air Con Condenser fan... if you can find one cheaply! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 3, 2008 Share Posted September 3, 2008 Shrek, Hard one to quantify mate but suffice to say improved enough for me to say 'well, that was well worth it, thanks Mr. Wightman' Mo Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 3, 2008 Share Posted September 3, 2008 The problem with a fan on an intercooler is that it restricts the natural flow, so on the road, you will get less performance from the intercooler. Basically, do you ever need sustained high boost when moving slowly?? If not, there is no point. I can't really see when or how you would ever be able to do that. One thing I have found is that on the 200TDI Defender, the stock fan couling substantially restricts air flow through the intercooler. Removing it improved intercooler performance by a huge amount. Quote Link to comment Share on other sites More sharing options...
TomG Posted September 3, 2008 Share Posted September 3, 2008 Mitsubishi's have an intercooler fan mounted between the bonnet and cooler. They look like the ideal size to go on a 200/300TDi one.Les. Excellent! been looking for a cooling fan to fit a 200tdi intercooler. ... on a v8 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 4, 2008 Share Posted September 4, 2008 Basically, do you ever need sustained high boost when moving slowly?? If not, there is no point. On a wet, clay, muddy play site, yes Mo Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 4, 2008 Share Posted September 4, 2008 On a wet, clay, muddy play site, yes Mo I remain skeptical. You need to be on full boost (i.e. full throttle) for at least 30 seconds. Sure you can be full boost for a short period, but not sustained. As soon as you go off boost the intercooler cools very quickly from the inside. Quote Link to comment Share on other sites More sharing options...
